Results 1 to 10 of 24
Thread: shock level with solid cover when closing?
    Aug 2012
    Iowa
    Default shock level with solid cover when closing?
    I read the sticky notes for closing, But I am ready to start closing with a solid cover and first time using a 4x15 air pillow." that should be interesting getting those 2 items in without throwing a fit and tossing the pillow in the trash before its all done.Since its a solid cover,should the shock level be less than what is on the best guess chart, I think that is around 20ppm?Read somewhere about not being able to out gas when covered.
    And speaking of the cover and pool pillow,when I tie off the pillow at both ends to the pool uprights and leave enough slack in the cords so cover can still rest on top of the lowered pool water,would it just end up moving around under cover even after I put some water on top of cover?
    I just bought a new cover, 20x36, which gives me 2 feet extra all around, but with the pool water lowered 6 inches below return, as in the past, that extra slack,which should have cover draped down side of pool wall and across water I doubt will be there especially with a pillow in the middle now and end up angled from the pool walls and over the pillow.
    Am I over killing this or doing something that's going to put too much pressure on the walls?
    Last winter, which seemed only weeks ago I found myself removing snow almost every 3 days.
    16' x 32' Above Ground Doughboy
    half surround deck
    Aquaview sand filter
    1 1/2 hp pump
    Gulf stream heat pump
    BigDave's Avatar
    Default Re: shock level with solid cover when closing?
    The cover should be slack and on top of the water. Let some air out of the pillow.
    Aug 2012
    Iowa
    Thanks, So I assume what I will do is ok, I haven't done all this yet, will do in a few days.
    As far as shock, with a solid cover,should I elevate the FC to normal shock level or reduced?thanks
    half surround deck
    1 1/2 hp pump
    BigDave's Avatar
    I bring to shock level as per the Best Guess Chart when I close.
    Virginia
    I think one of the OP's concerns is whether or not covering the pool with a solid cover after shocking will cause issues with the pool out gassing.
    After shocking, do you wait a bit before covering so byproducts have a chance to properly out gas? Or do you cover right away after shocking?
    Aug 2012
    Iowa
    That is correct,I do think I will shock to the 20ppm, then wait a few days for it to drop back to the 5.0ppm for my stabilizer level which is at 40ppm.
    Sound right?
    half surround deck
    1 1/2 hp pump
