Thread: Air bubbles in pump basket
    Jul 2013
    Northern Illinois
    Default Air bubbles in pump basket
    My friend's pool (see below for info) seems to consistently get small, circulating air bubbles in her pump basket. When I put her skimmer shut-off to half for a bit, the basket returns to full with no bubbles. A few hours later, same thing. Is this symptomatic of something?
    ~15K IG vinyl 1hp pump, Jacuzzi 225L filter
    Largo, Florida
    Default Re: Air bubbles in pump basket
    Suction side leak. Could even be the O-Ring on the gasket lid if she's lucky.
    Jul 2013
    Northern Illinois
    Oooh, thanks! I noticed the o-ring looked really dry.I tried to remove it to inspect it, but I couldn't even budge it! Will recommend getting a new one and then scrape away the old one, and replace. Sound like a plan?
    Jul 2013
    Northern Illinois
    As an aside, it's funny. My own o-ring falls out every time I clean the basket. Pain in the patootie! Thank goodness I use skimmer socks!
    Last edited by FormerBromineUser; 09-15-2014 at 01:00 AM. Reason: Remove signature
    Scottsdale, Arizona
    Quote Originally Posted by FormerBromineUser View Post
    Put some Pool and Spa Lube on it and it will hold it in place.
    Jul 2013
    Northern Illinois
    Hey. Could one of you hydraulics guys chime in on this thread if you have anything to add? Pool/Spa connection question: http://www.poolforum.com/pf2/showthr...012#post128012 Thanks!!!
    Yup. It should be soft and pliable.
  1. Pump basket lid stuck
    By cmcq in forum Pool Equipment & Operations
    Last Post: 10-02-2010, 08:25 PM
  2. air bubble in pump basket
    By mbar in forum Pool Equipment & Operations
    Last Post: 06-02-2008, 09:25 PM
  3. pump will only prime when basket it out
    By ScottsdaleSwim in forum In-Ground Pool Construction and Repair
    Last Post: 10-23-2006, 10:52 PM
  4. pump will only prime when basket is out
    By ScottsdaleSwim in forum Pool Equipment & Operations
    Last Post: 10-15-2006, 11:01 PM
  5. How often should you clean your pump basket?
    By Beachnut_PA in forum Pool Equipment & Operations
    Last Post: 06-26-2006, 12:20 PM
