That patch did not stop the leak. Lost 4 inches of water overnight. Got in the cold pool and found large areas the seam is separating. Liner has 25 year warranty, so pool Co coming Tuesday to take care of.
15,000 gallon Pearl Escape 24' 8" Frame 52" Pool
AquaSmarte Mineral - I do not use and have turned off.
SwimPro 26 w/2HP Pump 250 Sand System
I'm sorry it didn't work.
Are you sure you patched the leak? (the only leak?)
Are you sure it was completely sealed and 2 layers?
