Results 1 to 10 of 22
Thread: pool balance before closing?
    May 2012
    Kentucky
    Question pool balance before closing?
    My pool is empty, freshly painted concrete bottom, allowing to cure for several days. My question is, What should my numbers be to balance pool . How and when should chemicals be added while filling, etc? As soon as its balanced , It will be closed for winter. Thanks!
    17k gal 16' x 32' IG concrete bottom FG sides 1985 , Hayward Pro S244T sand filter , Hayward Super pump 1 HP 12 - 24 hrs , using 8.25% bleach, K-2006C kit. PF=7
    Default Re: pool balance before closing?
    Pool builders all seem to have different forulae and their warranty is tied to it. So follow yours.
    May 2012
    Kentucky
    Quote Originally Posted by CarlD View Post
    Pool builders all seem to have different formulae and their warranty is tied to it. So follow yours.
    I did the painting myself, I converted to epoxy from rubber paint. Hope it works out for me. No warranty involved. 30 yr old pool
    I am not sure about which chems to put in first, second etc. What can or should I add through skimmer? What can I broadcast over surface, etc? Thanks!
    Ouch! I'm not really that knowledgeable about masonry pools, so I guess I'd start with where you want to be. I'm guessing here and corrections by those who are more familiar would be welcome.
    Start by testing your fill water BEFORE you fill the pool so you know what's in it and where you're starting.
    FC: Depends on your CYA level, but initially, until you reach a CYA of 30 you'd want it to be between 2 and 5ppm.
    CC: Try to keep at zero
    pH: You'll want to keep it in the standard 7.2-7.8 range. While your pool is curing expect it to rise so keep muriatic acid handy.
    T/A: Your target for Total Alkalinity is 80-120ppm.
    CH: Calcium Hardness or Hardness. Masonry pools require 200-400ppm
    CYA: Stabilizer. We generally recommend a minimum of 30ppm, though higher can be manageable or desirable.
    How to get there:
    I'd always start with chlorine--keep anything from growing.
    If you start with Cal-Hypo (get it at least at 56%, 65% is better) then you're adding chlorine and calcium at the same time. If your water is already hard and in the 200-400ppm range, don't use it. You'll get about 7-8ppm of CH for every 10ppm of chlorine.
    If you start with Di-Chlor powder you're adding an initial dose of CYA with your chlorine, too. About 9ppm of CYA for every 10ppm of chlorine. It's slightly acidic.
    If you start with Tri-chlor powder (don't see it much) or tablets, you're getting chlorine, CYA (6ppm for every 10ppm of Chlorine) and it's very acidic.
    If you start with bleach/liquid chlorine you'll have to add CYA and possibly calcium flakes as well.
    You cannot mix them together in a slurry because it's extremely dangerous. I think, though the most important things to control first are chlorine and pH, after that calcium and T/A, and finally CYA (which can take 48 hours to a week to get to the right level).
    I cannot really advise you beyond this because I'm just guessing. But with most chems if you wait an hour or two before adding the next, you're OK.
    A lot of it is preference. You may start with a dose of Cal-Hypo to get your FC up, then when it's dissolved fill a floater with Tri-Chlor pucks. Or you may start with Di-chlor, and then fill the floater with Trichlor, and a little later add calcium. Or you could start with bleach/LC, add calcium flakes and tie a stocking filled with CYA to the side of the pool to dissolve. All will work.
    Just don't dump everything in at once.
    May 2012
    Kentucky
    Thumbs up Re: pool balance before closing?
    Thank You!!!
    Test your FILL water (pH, TA, CH only) and post those results. I can then calculate doses -- once your pool is full -- to bring you into a safe range for winter.
    If you have had problems in previous years with the pool being slimy on opening you may want to consider the additional steps of raising borates (> 60 ppm) and lowering phosphates (< 0.125 ppm) prior to closing. Alternatively, you can maintain intermittent chlorination while closed. I can help you pursue either or both.
  1. Pool green and out of balance
    By mvcarroll02 in forum Dealing with Algae & Slime
    Last Post: 11-09-2013, 12:31 PM
  2. New Pool Balance
    By parkinc in forum Dealing with Alkalinity and Calcium
    Last Post: 10-23-2013, 06:10 PM
  3. Winter closing IG BBB Safety Cover - Best Chemical Balance prior to closing?
    By blue wolverine in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-16-2012, 04:36 PM
  4. New pool and trying to balance the water.
    By mrup1012 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-13-2012, 12:37 PM
  5. Plan on closing today, but read about polyquat dosage prior to closing...
    By The Raddish in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-06-2006, 10:50 PM
