Not too uncommon to find a suction side leak in the skimmers. The decking shifts and cracks them. Careful visual inspection will frequently find them. If so, they're fairly easy to fix....hope it's that simple.![]()
Dave s.
Dave s.
Originally Posted by duraleigh
right i agree the most probable cause is the suction side skimmer plumbing however i am unsure how to find the location of the leak, i have checked carefully all exposed plumbing and its sealed tight, but it must be leaking because i lost 2" over night while the skimmer was on and when it was off i lost 1/3" maybe and it was a 90degree day here in south florida. thanks for your help
This is exactly where my leak was, in the skimmer throat. I was loosing about 1" a day. I hired a leak test company (@ $400) to find it. They found it by squirting phenol red through a long, thin tube. Wherever the leak is, it sucks the red dye right in.Originally Posted by duraleigh
Michael
Originally Posted by mwsmith2
hey thanks for your reply i got plenty of phenol red on hand and thin clear plastic tubing which i use for my fish tanks that will work perfect for this application. however once they found the leak on your skimmer troat piece how did they or you go about fixing this problem? the more help the better because this sounds really close to being my problem that or the plumbing coming from the skimmer which i am going to dig up tomorrow and see if any of that leaks. i will update and thanks for your help![]()
As I tried to point out in my original post, it sounds like a broken return line - that's where I'd look first.
The pool looses a heckuvalot more water while the pump is running, therefore water is being FORCED through the leak.
If the filter system is below water level, it could be backwash blow-by - I don't think so though (but I can't put my finger on why not) Also a pump problem would have been noticed.
A suction side leak would draw air into the pump, causing priming problems and bubbles, certainly not exacerbating the leak.
A stuck hydrostat valve or a cracked skimmer housing would cause water loss but, the amount of water lost daily would remain the same, whether or not the system was running.
It's always possible that you have multiple leaks in the pool, but given the discrepency between the water loss with the pump running vs. without, I'll lay odds on finding the main leak on the back (effluent) side of the pump
Yup I agree, if it leaks down faster when the pump is running, it is definitely on the effluent side of the pump.
As for how they fixed the leak in the skimmer throat, they used waterproof epoxy that the kneaded together and stuffed in the crack. They said it wouldn't be a permanent fix, but 1.5 years later, it's still holding fine. If it gives up, I'll go buy some more and stuff it in there!
Michael
Hey, I'm not gettin' hung out here by myself...I think it's pressure side, too!!![]()
The increase with the pump on slipped by me and I probably should've never brought up suction side as a first culprit.
After all that, I can see a remote scenario where it could be a cracked skimmer and I'd check it just cause it's easy to get to with the phenol red.
I agree that pressure check will find your issue...almost assuredly.![]()
Dave S.
Hey, ok one thing is bothering me let me explain a little better.Originally Posted by waste
the first test i did was fill the pool 2-3" above the skimmer level fill a bucket of water and mark both the outside and inside water level after that i turned on the filter and left it alone for 12hours, the result was 2" loss in water.
the second test i did i left the water level just below the skimmer, closed the valve so the skimmer suction line doesnt pull air/water and fill the bucket of water again and mark the inside and outside water level, turned on the filter and left it for 12hours the result was 1/3" water loss.
the third test i did was leave the water level just below the skimmer and fill the bucket mark the inside and outside water levels and leave the filter off and the water loss was about 1/3" maybe a drop less.
the final test i am doing is fill the pool 2-3" above the skimmer and mark the inside/outside water levels of the bucket and leave the filter off for 12hours and check results. i will post results tomorrow
Now if the leak was in the return lines to the pool wouldnt the water loss be the exact same during/after test 1 AND test 2? What i am planning to do as of now is dig up the earth to find both the suction and return plumbing and check the length of both for leaks, if any is found cut/replace pvc with new, if no leaks no big deal i just put the dirt back in the hole and waste a few hours work which i am willing to do.
I really appreciate everyones help on my problem and i am waiting until we work out the kinks here until i actually dig up or attempt any repair.
also to note no leaks by the pump/motor/filter, i will try to conduct the phenol red test on the skimmer housing tomorrow sometime in the afternoon, NEEDS to be mentioned anytime the filter system is turned on after priming coming out of ONE return line is a constant flow of tiny bubbles but not very many at a time. as far as the pressure test i am still looking for research on this test online and i would love to conduct it if i am able and have the tools.
Thanks again to everyone.
Okay, since my buddy, Oxoroniox (man, you need a better username![]()
) isn't completely convinced about the pressure side leak, I'm going to post my "pie-in-the-sky" scenario about it being in the skimmer.
I can envision a crack in the skimmer running diagonally to the water flow and very near a point where the water is forced to change direction. With no flow through the skimmer, the sides of the crack stay virtually together and there is almost no leak.
When the pump comes on, however, there is enough pressure from the redirection of the water that the thin plastic sides gap open a little allowing quite a large volume of water to escape. If this is feasible, I do not think this scenario would intake air.
Okay, Okay, I'll start drinking less from now on![]()
