Results 1 to 10 of 18
Thread: Using 1-25 Micron Bags in Skimmer
    Jun 2014
    South Carolina
    Default Using 1-25 Micron Bags in Skimmer
    My husband and I are both disabled, and we're finding that we cannot stay on top of keeping the filter cartridge clean. Since we've been trying to tackle an extremely green pool, the filter ends up needing to be cleaned more than once a day. And it's just not happening.
    I am "able-bodied" but legally blind. So, my main challenge is the intricacies of removing the lid from the pump and then replacing it. I haven't tried to do it, but my husband says it can be difficult for him to line everything up properly, even with normal vision.
    So, I was wondering, could we ease the load on the filter by putting a 1-25 micron bag like this in the skimmer? And, if so, which micron rating should we use? Would 1 micron put too much strain on the pump?
    Like I said, I'm able-"bodied". So, I can clean a skimmer sock all day if I have to as long as there are no small details like screwing something back in place.
    Default Re: Using 1-25 Micron Bags in Skimmer
    Hi:
    Frankly, I think you are asking the WRONG question, dangerously wrong for your health and your husband's. The question I think you should be asking is:
    "Why is my pool green and what can I do to prevent it, so it stays clear, clean and sanitary?"
    IOW, your pool is probably infested with algae, and the algae's presence means you don't have sufficient chlorine to sanitize your pool, kill all the nasty, dangerous bacteria that can make you very, very sick or worse. Algae is the canary in the coal mine warning of unsafe bacteria in your pool.
    But if your green is not from algae, then it's from excessive metals, mostly copper, in your water and that needs to be addressed as well.
    Trying to filter this stuff out is about as effective as spraying deodorant on dog droppings.
    Jun 2014
    South Carolina
    I've been putting bleach in the pool and testing it, even shocked it a few times. We can get the green to subside, but the filter clogs so quickly it's disheartening. The filter stops pumping anything, the chemicals stop circulating, and I give up. Then, the algae starts coming back.
    We can't just get away with leaving the filter so dirty the pump doesn't run at all, can we? If we can, I'll just go about my business with the bleach, borax, baking soda, and stabilizer. Otherwise, it just feels like a lost cause.
    I strongly suggest you start reading our sister-site, PoolSolutions.com and start learning how the BBB system works. It's more of an idea of effective simple techniques rather than a dogmatic use of bleach, borax and baking soda. I use bleach, liquid chlorine, occasionally Tri-Chlor tablets and Di-chlor powder, but principally use my SWCG for chlorine. I'll use Borax or Washing Soda to raise my pH, almost NEVER use Baking Soda (because my Total Alkalinity is, for various reasons, rarely a problem).
    The BBB system is based on 3 things you MUST control:
    1) Sanitation. That's your chlorine and if you have algae, the chlorine is being spent killing that and not the dangerous and even deadly microbes that can get in your water.
    2) pH: This is how acidic or basic your water is. Acid attacks your pool walls and you. Basic water inhibits chlorine's ability to kill bacteria and algae. So you must balance it.
    3) Stabilizer (aka, CYA for Cyanuric Acid): This is like sunscreen for your chlorine. Without it, UV rays from the sun can break chlorine down in as little as 15-30 minutes. CYA protects the chlorine BUT it is a 2-edged sword. It slows chlorine's break down, BUT you therefore need more chlorine to balance that out. It's a relationship and we use our "Best Guess Table" to tell us the best chlorine level for a given CYA level.
    http://poolsolutions.com/gd/best-gue...ine-chart.html
    But none of it works without a good test kit and we recommend the Taylor K-2006 or K-2006C as the best home-owner kit. There are a couple of equivalents, but they cost the same or more. All are only available on-line.
    Here's the link to the Taylor kits: http://www.poolforum.com/pf2/showthread.php/14994
    Without good testing and a knowledge of what those tests mean, you are flying through a fog, but with no instruments to guide you. You are guessing and your persistent algae means you are guessing wrong.
    I'm sorry to be so blunt but I believe you are putting yourselves at a terrible risk with what you describe. Without good testing and effective chlorination, your pool won't be, IMHO, safe to swim in.
    With what you describe, there is no easy answer or magic bullet to fix it, and anyone who tells you there is cannot be believed.
    But the fix is not complicated or magic. Test, adjust pH, add stabilizer, chlorinate heavily to KILL the algae, vacuum, brush the walls, and be patient and persistent.
    Best I can do. The rest is up to you.
    Jun 2014
    South Carolina
    I have read a bit on that site. And I do test regularly, albeit with a cheaper test.
    This may be a dumb question, but when should I shock, when should I vacuum, and at what level should I keep the chlorine while the filter is constantly getting clogged?
    I do not feel able to vacuum the pool without getting in it. So, it seems like I have to do one or the other but can't do both.
    I cannot keep saying this: You need to give us test numbers on your chlorine, pH, and CYA levels.
    You need to read our stickied threads on dealing with algae.
    And if you have algae you need to be shocking two or three times a day. You cannot filter your way out of an algae bloom. You must kill it.
    I think Carl is trying to communicate this:
    ==> You need to KILL the algae, BEFORE you worry about anything else! <==
    As he's pointed out, we need other info, to give more specific advice, info that you are finding it difficult to supply.
    I'll suggest an alternative approach:
    1. Tomorrow night, REMOVE your cartridge or "filter sock" (??), replace the lid, and then turn the pump back on. THEN, add 2 gallons of PLAIN 8% household bleach for each 10,000 gallons of water in your pool.
    2. The following day, if the algae is ALL dead, add 1 gallon of bleach per 10k gallons, brush the pool, and test the water with a cheapo OTO / phenol red kit. If the algae is MOSTLY dead, repeat the dose. If the algae is NOT mostly dead, add a 3 gallon dose.
    3. The third day, if the algae is ALL dead, add 1 gallon of bleach per 10k gallons, brush the pool, and test the water with a cheapo OTO / phenol red kit. If the algae is MOSTLY dead, repeat the 3 gallon dose. If the algae is NOT mostly dead, add a 4 gallon dose.
    4. Keep walking the dose up, each evening until the algae is dead. THEN, we can worry about filtering and such.
    Thanks, Ben! That's EXACTLY what I was trying to say!
    BTW: Don't freak out if all you find is 8.25% bleach, rather than 8%. It's the same thing. Just use the 8.25% EXACTLY as Ben says as if it's 8%. EXACTLY AS HE SAID!
    Jun 2014
    South Carolina
    I am disabled and poor. If I cannot find a way to manage filtration issues myself, there is no point in wasting my meager income on bleach. This is why I asked this specific question. Why start or continue a task there is no way for you to finish?
    You don't seem to understand:
    If you don't kill the algae, your water is not safe no matter WHAT filtration you use! You cannot filter your way to sanitary water! Better off to drain the pool and not use it.
    I cannot help you if you will not listen to what Ben and I have to say and I will not attempt further to help you. We are all volunteers here and give of our time freely.
    Best of luck to you!
