Re: Max Chlorine PPM for Fiberglass Pools
I have a white fiberglass pool also. I have had my shock levels way up there - this was before I found this forum. I can't tell you how high, but I know I threw bag after bag of shock per the pool store's instruction. As for damage to the gelcoat - I have not seen any evidence of it - I also know that when they repair cracks in the gelcoat, they sand them down, and the gelcoat is pretty thick, so I don't think going high with chlorine for a short time would co any damage. On the other hand, I really think that there is something in the fiberglass itself that makes it very suseptable to staining. I thought about the calcium too - but the first year I got the stain, was the spring I switched to chlorine. The pool store had me put in tons of calcium, and tons of shock, because my water was green. They even came over with an extra pump - I kept telling them that the water did not seem due to algae - it looked like a chemical reaction - but they said, no, it just needed more calcium and shock - needless to say I ended up with a cloudy lime green pool. I went to a different pool store and had a water test - my calcium was at 550!, and my chlorine was higher than their test went. They suggested a drain of 1/2 the water and refill. It was when I drained that I saw the yellow stain all over the pool - that's when I decided to learn how to take care of my pool myself. So, I researched staining and have been researching it ever since! The conclusion I have come to is that fiberglass is very suseptable to staining - metals will always find a way into the pool, but the fiberlass seems to react very easily to any metals (calcium is a metal), and a combination of high chlorine with high ph seems to make a stain cocktail in fiberglass pools. I have tried different chemical balances in my pool, and the one that has seemed to work the best is: Low ph 7.2 - 7.5, medium cya, so I can run my pool on lower levels of chlorine, alk about 80 - 100, and calcium at about 125 - 200. I tried running very low calcium, but had stain - so I think Waterbear is right about the metal pulling out of the fiberglass if there isn't any calcium in the water. But most important is to KEEP SEQUESTERANT IN THE WATER AT ALL TIMES. I also notice that keeping the filter running 24/7 works for me. Keeping up with my pool so I don't have to shock is one thing I try to do, but I do shock every now and then, and I make sure my ph is low when I do. Hope this helps all fiberglass pool owners - I love my pool, and even though it doesn't sound like it, it really is very, very easy to take care of.
The blue water in the white fiberglass is due to the refraction of the light from the sky (according to a very smart person). That's why it appears bluer some times more than others.
Northeast PA
