Results 1 to 8 of 8
Thread: Can't maintain free chlorine
    Oct 2014
    St. Petersburg FL
    Default Re: Can't maintain free chlorine
    So if I understand correctly. If I'm currently am at 2.5 FC and I get 2 1/2 gal jugs of 12.5% LC I would add 3 gals-one jug and about half of the second jug. Correct? Thanks again. Rick
    Oct 2014
    St. Petersburg FL
    on the shock chart it looks like shock level of 28 for a salt water system with my level of stabilizer. You note 20 in your response which is what I have it at right now. Is that ok? Thanks
    What shock chart?
    Adding amounts of chlorine according to your volume and current FC level is approximate. but you should add three gallons of 12.5%, not 2.5
    Oct 2014
    St. Petersburg FL
    I may be done. I will check in the morning to make sure haven't lost more than 1 in chlorine. Combined chlorine is 0. Thx
    Oct 2014
    St. Petersburg FL
    This is the link for the chart http://www.troublefreepool.com/conte...art-slam-shock. Last nigh FC was 20. This a.m. was 18 so guess not done. I just want to make sure I am getting FC to correct level (ie the 20 vs 28). Thx
  1. unable to maintain chlorine levels
    By Coman in forum Dealing with Algae & Slime
    Last Post: 08-19-2013, 07:18 PM
  2. I can't maintain chlorine in my IG vinyl pool
    By Nysitemgr in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-13-2013, 10:42 PM
  3. How much chlorine per day to maintain?
    By Mm_putnam in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-06-2012, 09:59 AM
  4. Clear Pool but cannot maintain free chlorine level?
    By Mr.Mooks in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 08:47 PM
  5. Unable to maintain chlorine levels
    By medstudy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-18-2006, 03:43 PM
