Can they be had? I like the convenience of the dispenser, but don't want to get the CYA levels too high.
Sure. There are Cal-Hypo based tablets, that add calcium rather than CYA. Unfortunately they tend to dissolve rather quickly and turn to mush, unless you get the type in a plastic capsule. And you MUST NOT put them in the same feeder as Tri-chlor tabs (the ones that add CYA).
But they are, IMHO, a really lousy alternative to Tri-Chlor tabs.
As Carl noted, cal hypo tabs don't perform as well as trichlor tabs, in a feeder. I've never tried them in a floater, so I can't say how they work.
There are some VERY expensive feeders designed for commercial installations, but they aren't very practical for residential use.
But . . . if you are looking for a 'easy' method, running a pool the way the chlorine gas 'shooters' in Arizona, California and Texas do: adjust the CYA to 100 - 150 ppm and dose weekly with 10 - 15 ppm of chlorine. They used to use various algaecides, but you if you maintain very low phosphates (PO4 < 0.1 ppm) you can accomplish the same thing. (You don't want to have to use chlorine as an anti-algae treatment when CYA > 100 ppm, since that requires FC levels as a high as 50 ppm).
PoolDoc / Ben
I put the Cal-hypo tabs in my skimmer once and in 2 hours they were mush and the skimmer was jammed up....Not a fan!
I don't think that's typical of all CH tabs. However, you could work around that in several different ways, such as putting them in a perforated plastic bottle that's resting in the skimmer.
Interesting idea, but I haven't had to mess with it in years.
How does the commercial feeder work?
I have a chlorinator sys in the well house that uses a holding tank I fill with a bleach/water mixture and a chem pump (piggy backing my well pump) that pumps it in. Wondering if I could find some 100% sodium hypochlorite somewhere and use a similar pump to meter it in. I have a RS6 controller with a spare relay I could program to do pretty much whatever.
Outta my league here. Just bumping thread cause I see you're checking for responses.
Bleach is sodium hypochlorite mixed with brine, which is saltwater. Strongest I know of is nominal 12.5%, which, when fresh cam test as high as 14%.
I did a bit more reading and discovered 100% sodium hypochlorite is a solid, unstable and very hard to find. Guess that's out.
Wish I could find an alternative to buying gallons and gallons of bleach every week. Seems like there would be a market for CYA-free tabs if they were available.
IG concrete 30k gal FNS60 DE filter 2hp single speed Haywood pump
