Re: Closing chemistry recommendation
zmanh
Thanks for the reply. I was getting plenty of questions from my wife on why I hadn't closed yet. (both neighbors had) And I honestly couldn't answer it, so I ended up closing. Know better next year. I am using a mesh cover, since I don't have a cover pump. Plus I have plenty of leaves to deal with so didn't want those getting on cover, getting wet and weighing it down. I have plenty of tree trimming to do this winter to hopefully remedy that. On behalf of those of us that may not comment as much, thank you all at the pool forum. I made a few mistakes my first year. (had no idea how much of an effect 12 kids taking swimming lessons would have on chlorine drop) I paid for that by spending the next 2 weeks fighting algae. The threads, stickies, articles, etc. were very helpful.
I didn't find this site until after several seasons of trying to figure out why the pool store's recommendations weren't working. Now, by following the recommendations here, maintenance is much easier and cheaper.
Since you're using a mesh cover, I suggest you plan to open in early March. Here on the VA coast I found if I opened later than that (when I was using a mesh cover) I had a good chance of opening to a green pool. Since using a solid cover, I've not had a green pool in the spring even opening as late as early June. You're right though, the solid cover does get messy.
You said you don't have a cover pump. Since you have a mesh cover, you will still need a pump to drain excess water that will accumulate in your pool during the winter. And since all that rain will dilute your pool water, you should probably plan to add another dose of polyquat, perhaps in January or early February.
