CarlD
While 925# seems like a lot, you ARE filtering a spa, which I presume requires a much higher flow rate for all the jets if it's a single pump--I'm guessing as I know nothing about spas. But he's 100% correct that the filter MUST have a greater capacity than the pump. With filter that large you may WELL see fantastic performance that makes DE unnecessary. You can always try it, and if you don't like it or you put in too much, you simply backwash and VOILA! it's gone!
Be absolutely certain he installs surge protection for your VS pump, not just GFCI. They are very sensitive to surges and lightning, having electronic circuit boards. While they do perform better than a 2-speed pump, they are more sensitive because of the electronics.
These days, with all the electronic appliances, surge protection is everywhere. We have to have it on our washer and dryer, even though the dryer is gas, because they are electronic. We have lost too many coffee makers till I put a surge protector on the latest one! We even have a fridge and range that have them on them (gas stove, electronic controls)!
