I have to disagree. While it is true many SWCG owners have a rising pH problem, not all of us do. In fact, I NEVER do. You can always install an acid pump later if you find it's a problem. You WILL have rising acid when your pool is new, but if you just buy a couple of $10 floating chlorinators and fill them with Tri-Chlor tabs, they will control your rising pH during the 6-8 week curing period and add some of the CYA you need, too. You CAN use chlorine with an SWCG without a problem.
It's too easy to get into the buy, buy, buy mode when it's new and while we can frequently all be equipment junkies, it's better to learn and master the BBB method FIRST and use the equipment to augment that, not replace it.
I agree with Carl.
I seemed to have found the sweet spot with TA and borates in my pool (TA about 80, borates about 60). This is the second season I haven't had to add a single drop of acid to adjust pH. It seems to level off at 7.5-7.6 and stays there the whole season.
