Well, time to winterize
So, we got a good two months out of the pool... I had it heated this last week and the family was swimming last night with 47 degree temps and the pool was at 98 degrees...
But, now it is time to winterize it, and I have a decent handle on most of it, but I do have a question in regards to the "excess material" my liner has.
As it stands the liner is a little oval for a 27ft round pool. there is excess on both sides directly across from one another. I currently have it pulled into a seam about halfway down the sidewall on both sides. it starts as a small crease and then becomes a good 2-3 inch flap at it's thickest on both sides of the pool.
I do plan on replacing the liner in spring, but for now I was hoping to winterize it, so I have three options I see:
1) Pull the excess all the way to the bottom. Difficult because of the water pressure. I would also need to get goggles and a snorkel system to do it underwater easier.
2) Pull the excess all the way to the top and either tie it back with tape or some other means. Concern here is that is would come undone and pillow out above and potentially rip if it gets caught in ice.
3) Do nothing. Concern here is that the excess would get entrapped in ice and that would end up ripping the liner by shifting.
Now I plan on draining below the returns, using plugs, plugging the skimmer, removing all the hardlines, putting in antifreeze in the main drains and blowing out the lines, etc... Just that I am concerned about the liner ripping and the pool leaking out over winter.
There is no way I would change a liner now, especially since I am not done with the paver patio just yet (close, but not done), so that needs my attention.
Any and all advice is appreciated.
I plan on putting on a winter cover and air pillow as well as putting on it an automatic water pump to keep water pumped off the cover.
