Thread: Well, time to winterize
    Default Re: Well, time to winterize
    This is the slow time of year, and getting slower. We're down to a crawl and soon even that will end. While I do have ice every winter, as bad as my liner ever was I cannot even visualize what you are describing. Since you are planning on replacing the liner, I can only give a wild guess as to what's best. My first suggestion would be to NOT cover the pool, leave it open. That way, in the liner ruptures, a cover weighted down with water, ice and snow won't pull down your walls. My second suggestion would be to add guy lines to the outside so if you lose water you have additional support to prevent it collapsing inward.
    But as I said, I'm guessing.
    DennisP is offline Registered+ Thread Analyst DennisP 0
    Jul 2014
    New Berlin, WI
    Thanks for the reply...
    As it turns out I am not using a cover, and no pillow either...
    With all the cold we had so quickly this month, the pool is already an ice cube... I don't know if it goes down very far or not, I haven't been out to check on it since I have been recovering from doing 12-16 hour days getting the patio finished... My hands are still far from "good" and still heavily calloused.
    I did get all the hard lines off, lines blown out (added about a gallon of anti-freeze per line "just to be sure"), everything plugged and added about 3 gallons of anti-freeze into the main drain on the pool. Everything is capped off and "done". Water was drained to about 2-3 inches below the returns. Basically got it all done the day the cold front moved in, as the temp dropped from 39-40 in the morning to about 30 degree as I was finishing up at 2-3pm. I drained the cartridge filter, even removing the plug underneath and fully draining it, as well as bringing in the pressure gauge. The filter is still outside, as it will take me another week or so to make room in the garage for it. But, eventually the heater and the cartridge filter will be moved into the garage as well.
    Jul 2013
    Northern Illinois
    Best of luck! Curious to see what new liner you pick!
