Results 1 to 10 of 20
Thread: Using your kitchen faucet to heat the pool
    Default Re: Using your kitchen faucet to heat the pool
    Quote Originally Posted by sevver
    What would you do with the water that you displaced by putting in the water?
    Running the garden hose from the sink for an hour shouldn't have much of an impact on the water level. At least it doesn't when I run just the straight garden hose. I'm lucky if it gets a millimeter higher. Even if it does have an impact though, the water just replaces the water that is evaporated during the day. I think that part of it should be fine.
    I just didn't know if it would make any sort of an impact since we're dealing with 24,000 gallons of water here. But, maybe it would. If know one has tried it, maybe I'll make a trip to home depot to get the adapter and try it out. Before going through that, anyone try it or think it would/wouldn't work?
    (By the way...I'd love to get a heater and probably will within the next few seasons, but for now...)
    Indiana.
    It takes 8 BTU to raise a gallon of water 1 degree. Just as a SWAG, let's say the pool is at 80F, water heater is at 120F. Each gallon of water from the water heater then has 8X40=320 BTU more than the pool water. Divide that by the 24,000 gallons in the pool (ignoring the gallon added), and you will have .013333BTU, which would raise the pool temperature by around 1/1000th of a degree. The BTU content of the water in the heater starts dropping as soon as you start using it, so this is best case. Even with a 100 gallon tank, you are talking about raising the pool temp by only 1/100th of a degree. The cost would be astronomical too.
    Pool heaters are on the order of 400,000 BTU per hour. You aren't in the same ballpark.
    Quote Originally Posted by JohnT
    Nicely done!
    Why not hook a hose thru the cooling system of your car and heat it that way?
    cygnusecks is offline Unconfirmed User Thread Analyst cygnusecks 0
    Orlando, FL
    Of course, all of these methods are a waste of time once you see the Redneck pool heater. http://www.redneckpoolheater.com/.
    Katy, TX
    Quote Originally Posted by imfignewton
    Because that's even more inefficient than a water heater.
    Michael
    NERD ALERT!!! Just kidding. Thanks for the great response! Saved me time and money.
    Green Bay, WI
    I swear I should patent this. But someone should make a matt that is black and would sink to the bottom of your pool. Like a solar cover, but that sinks and is black to absorb the sunlight. Then once the pool is as warm as you want it you take it out. It amazes me all the people that have really light blue or almost white colored pools and then wonder why they never warm up. A friend of ours is building a new pool, she originally wanted black pebble Tec but the dealer told her the pool would get to warm. We are in Wisconsin for crying out loud! For the 2 weeks it is really hot you could run a fountain, but for the other 12 weeks you need all the heat you can catch.
    Maybe I am crazy and it wouldn't help.
    Rehoboth, MA
    What you describe is exactly what a solar heater does. Instead of sitting on the bottom of your pool it either sits on the ground or on a rack or on your roof and it hooks up to your pool pump. It heats the water as it passes through using the sun and using a solar blanket at night will help keep the heat in the pool.
    Peter
    Green Bay, WI
    I understand that it is the same thing as a solar heater, but it would be in the pool, cost no money to run, no pumps, no messing with plumbing and doesn't take up any more space then the pool already does.
