Results 1 to 10 of 22
Thread: WHite water mold- new pool owner
    Default Re: WHite water mold- new pool owner
    Yes. Or you could get a simple, new OTO/Phenol kit. If you can, try to find one that goes to 5ppm not 3. Leslies stores sometimes sell the Taylor version of the OTO/Phenol kit, the K-1000 and that goes to 5. If the phenol red reagent is the R0014, that's even better as it neutralizes chlorine and allows accurate readings when the chlorine is higher (Higher FC levels cause pH levels to read higher than they really are).
    If your chlorine level is above 5ppm (or above 10ppm with a Taylor kit), the pH will read falsely high. So, if you need to test pH while the chlorine is high, dilute your sample -- half pool water and half distilled water. Then test and interpret the results as usual.
    Oct 2014
    east central Florida
    Thumbs up Re: WHite water mold- new pool owner
    OOPS!!! my husband helped me unload my super-wally-world purchases @ $156 bucks and~~~~I asked him to pour 1/2 of a 2 qt bottle of bleach in the pool. When I walked in the garage I saw the bottle in the recycle bin-
    He had poured ALL 2 QUARTS in my pool WHAT to do NOW ??
    As far as the R0014 at walmart Carl, they only had AQUACHEM replacements and 3 way kits. And only 1/2 of an aisle devoted to pools- in FLoRIDA. hmmm, so now my PH is 7.8 and I did the distilled formula you told me to do ( this kit went to 5 ) Chlorine is a little darker yellow at the 5 line. - I know I'm over 20 ppm.....My pool is covered-SUN doesn't shine on it. It is crystal clear though.
    I'll do another reading in the morning. please advise o.O - And I screwed up BIG TIME !
    Just read your post watermom- I'm on it- thanks..PH is still 7.8 with the 1/2 & 1/2 test
    AG-Vinyl 1500 Gal 52 inch deep, 8 ft X 6 ft, intx "A" pump 637R, intex SWCG CS8110
    RayVac elec heater-ELS 552-2, skimmer. tayl 2006 in amaz cart -6 way strips atm
    Nothing you can do about the bleach now that it is in the pool. Adding 2 quarts of 8.25% bleach to 1500 gallons of water would have added about 27.5ppm of chlorine. Don't worry -- it will come down on its own.
    Oct 2014
    Sigh-oh thank you Watermom. I was just reading about http://store.pinchapenny.com/product...tralizer?s=120 on their site- and if I don't have to go there that is great
    Well it SHOULD kill all that white mold and those spider things!
    Oct 2014
    LMAO !!!!!! Carl, yes, yes it should. I'm lololing so hard right now
    Oct 2014
    Well, I have Been working hard on my pool, keeping it clean, & testing 3 times a day. Also, shutting down the pump in the morning to let sediment fall before vacuuming, brushing and skimming-then turning it back on for the night.
    My PH dropped to 7.6 watermom the chlorine is still unreadable- getting less and less blackish sediment. very clear water. Waiting on my K2006 & waders- I need to change that filter- have 7 of them. 60 degrees is tooooo cold to change them- It would probably put me into a flareup- If that happens i'd be down and out for a few weeks.
    I have a QUESTION: Is the TSP ( trisodium phosphate ) the red box. Is it a good/safe filter cleaning product ?? I read POOLDOCS ( Bens) post on it. Want some other input. Thanks.
    ALL is well CARL, EXCEPT: my SPIDER ALIEN FRIENDS FROM hell
    They are now skipping on top of the water-Not as many, But~~~~ I have taken up a collection jar, as they are a little bigger and more defined. i.e. ( legs and antennas) I plan on dumping them on a black napkin and taking a photo, S@@N. UGH ! As long as they reside walking on my water, I won't be doing any hydro-therapy. I'm very upset about this. And am thinking of taking pool down if they don't DISAPPEAR. 7 years of saving for this. But, I will give it more time. :/ Appreciate any comments.
  1. White water mold.Help needed please.
    By raven2963 in forum Dealing with Algae & Slime
    Last Post: 07-21-2014, 11:04 AM
  2. Closing with "pink slime and white water mold"
    By CarolineM in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-02-2014, 01:09 PM
  3. White Water Mold/ Pink Slime problem--- First steps....
    By weeznur32 in forum Dealing with Algae & Slime
    Last Post: 07-01-2013, 08:43 PM
  4. White water mold and pool floats
    By formisoul in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-12-2011, 09:06 AM
  5. Pink Algae and White Water Mold in Pool
    By pclstuff in forum Dealing with Algae & Slime
    Last Post: 06-07-2011, 05:26 PM
