Thread: Resurfacing Gunite Pool - Don't worry about the water?
    Apr 2014
    Default Resurfacing Gunite Pool - Don't worry about the water?
    Hello,
    Few questions for everyone:
    1) I'm working on getting my old gunite pool resurfaced. It's pretty badly etched and there is no way to compeltely remove the algae at this point. I'm wondering if I need to worry about trying to kill/keep the water clear or if I can just let it go before the resurfacing is done?
    2) Also, the drain at the bottom of the pool doesn't appear to be working. Is that a problem that should be repaired or not really a big deal?
    3) On person I talked to said he would rip up all the concrete around the pool (it's cracking and leaking water through and around the side of the pool) and redo that to protect the pool - necessary?
    4) I've got old copper 2.5" pipe - should that also be re-worked to 3" pvc or similar? That was the suggestion I got.
    5) Is it necessary to re-do the coping? The pool is about 50 years old at this point and I'm not sure if anyone has every done much too it...
    Any other thoughts/opinions, etc. would be appreciated. I'm looking at costs and it seems like it's going to be about 6500 to replaster and retile without doing anything else, compared to 15-20k+ to redo plumbing, concrete, coping, plaster, tile, etc.
    I don't care if the pool isn't "brand new" but I also don't want to skimp when things really should be done. I'll figure the money out if I have to to protect the investment and improve the property value/enjoyment.
    Jul 2013
    Northern Illinois
    Default Re: Resurfacing Gunite Pool - Don't worry about the water?
    Sounds like a pretty big project to me. Point 2: How are the skimmers? Point 3 sounds like an issue you should address. Hopefully someone with experience in this area will chime in. Good luck
    mas985's Avatar
    Pleasanton, CA
    1) Since they usually remove the old plaster, I think it is ok to leave it. They will probably power wash anyway.
    2) Not a big deal: http://www.poolinspections.com/manua...out-drains.pdf
    3) You could probably seal the cracks but it depends on how large they are.
    4) I would suggest changing to PVC but the size depends on the applications. In most cases, you shouldn't need more than 2.5" unless it is a high volume spa (> 6 jets).
    5) Depends on the condition
    Mark
  1. Filter Cartridge is green but pool water sparkles, should I worry?
    By MichaelC22 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-11-2014, 12:16 AM
  2. Experience with fiberglass resurfacing of Gunite pool
    By vousdoo in forum In-Ground Pool Construction and Repair
    Last Post: 08-02-2013, 08:11 AM
  3. Resurfacing a plaster/gunite pool with fiberglass
    By casicielo in forum In-Ground Pool Construction and Repair
    Last Post: 05-28-2013, 08:43 PM
  4. resurfacing gunite pool. Replaster or paint?
    By jdamiens in forum In-Ground Pool Construction and Repair
    Last Post: 08-14-2006, 05:33 PM
  5. New Pool Owner/Chemistry Worry?
    By mkfmedic in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-22-2006, 02:42 PM
