Thread: Resurfacing Gunite Pool - Don't worry about the water?
    Jul 2013
    Northern Illinois
    Default Re: Resurfacing Gunite Pool - Don't worry about the water?
    Sounds like a pretty big project to me. Point 2: How are the skimmers? Point 3 sounds like an issue you should address. Hopefully someone with experience in this area will chime in. Good luck
    mas985's Avatar
    Pleasanton, CA
    1) Since they usually remove the old plaster, I think it is ok to leave it. They will probably power wash anyway.
    2) Not a big deal: http://www.poolinspections.com/manua...out-drains.pdf
    3) You could probably seal the cracks but it depends on how large they are.
    4) I would suggest changing to PVC but the size depends on the applications. In most cases, you shouldn't need more than 2.5" unless it is a high volume spa (> 6 jets).
    5) Depends on the condition
    Mark
