Results 1 to 10 of 38
Thread: My feedback on main drains in an above ground pool...
    DennisP is offline Registered+ Thread Analyst DennisP 0
    Jul 2014
    New Berlin, WI
    Default Re: My feedback on main drains in an above ground pool...
    What, if any is the "down side" to a main drain???
    Sorry, I already stated the rest above everywhere... You have yet to address that single point.
    As far as it being a possible "leak point", again, no more than any other hole put into the liner for any other purpose (such as the skimmer/returns/etc). As far as it being an entrapment, again, dual drains far apart = no entrapment hazard, especially when cut in with the skimmer.
    Mark, I fully respect the engineering side you champion, and I am usually the first and foremost to do function over form. In this case it is just common sense based upon the usage I have and the fact that it is drawing water in from the center of the pool at the bottom. That in of itself overrides any other "noise" from arguing against it. It allows for complete and total turnover of the water in the pool constantly with the best mix possible within the shortest timeframe. Which is primary for heating a pool, cleaning a pool and even sanitizing a pool as far as I am concerned. Oh, and I may add, that yes the main drains to cause enough suction to pull the solar cover down in the center if there in rainwater sitting on top of it. In those cases we go out and roll the solar cover up and refloat it after to get the extra rainwater to mix with the pool water.
    Outside of entrapment with older single drains, I fail to see any sort of downside of using a main drain. It offers far more options and flexibility with absolutely no downside whatsoever if used with proper valving. I still fail to see the argument against them (outside of a pool builder/maintainer not wanting to deal with customers with them). If I don't want to use the main drain and want max surface cleaning effect, I can just switch it off (and I have valving at the pool and at the equipment pad, so I can do it where-ever it is convenient). Conversely I can also switch off the skimmer if I want the main drains to do all the work (and I sometimes do that to optimize the pool heating).
    And, if you consider the installation of a main drain as the big reason not to have one (which for the majority of people the reason they put up above ground pools is because they are easier to do and a main drain negates some of that "ease"), in my case that is not the case at all. I have autistic children that I would worry about constantly if I had an in-ground pool. For me it wasn't even an option, so I put all the piping for my pool in-ground, hard piped everything with 2" PVC and located the equipment pad at the back of the garage and built a 1200sq/ft paver patio around the pool, so putting in a main drain was trivial in comparison. This way I have zero concerns about the kids and the pool piping and anything else concerned in the backyard. It is fenced in entire with wrought-iron fencing (real wrought iron that is welded and solid) so I can let the kids out in the backyard with no concerns at all. I did all the work, including the patio, so an in-ground would have been a cakewalk to do at the time, but the worry with the children didn't make sense, so an above ground was the only option.
    Besides, I can always pull the pool and fill in the area with dirt, a fire pit, gardens and sitting walls when we no longer want to have a pool. I don't have to touch the paver patio or the rest of the landscaping when we get to that point and it all still "fits"...
    27ft Round x 54in deep Morada 6 Above Ground Pool; Sta-Rite System 3 S7M120 cartridge filter; Pentair Dynamo 1.5HP 340206 2-speed pump; Laars Lite2 250k-BTU millivolt NG heater; Dual Hayward Main-Drains, Dual Returns; plumbed in-ground w/2" PVC pipe; pool fill bib and line; 1238 sq/ft paver patio
    Anonymous [GDPR] European in the UK Guest
    Hi Dennis, hope your not getting upset? I did note a change in your post as it seems we are challenging you. I am not, I am just discussing. The point of discussing is to see if I have missed anything on the main drain topic.
    In your previous post you say "Honestly, most of this is about actual experience and what you have to deal with".
    It's the same for me. I started off in swimming pools just doing what I was told, believing everything the man in charge said.
    My background is engineering, hydraulics and pneumatics so I do know a little more than the average pool builder. For me the greatest influence and most astounding turnaround was 4 years ago from the report on main drains and pools without main drains documents and links that mas985 posted. That was something that stuck in my mind and I thought over it for a long time. It's not rhetoric and the flow from the computer fluid dynamics is something used on aircraft design, space craft design, in fact anywhere where a gas or liquid has to flow.
    I have played with pools similar to yours and noted the effects of opening and closing various parts and the quite frankly stupid ideas that the industry has as facts that we all follow. The key difference is I also have used the version without main drains and over large pumps and I couldn't believe the results. My pool is now a bit of a wreck as it is my test bed. I am fortunate that some of my customers have become friends and if I ask them can I experiment a little (no harm will come to their pools) they indulge me to play.
    That main drain in the video, it's flowing at a massive 795 gallons per minute, 795! yet unless the dye gets within 2"-3 " of the grill it doesn't get sucked in it flows right on past. That fact is probably the single most important point on main drains.
    The CPO teaches that 90% of the contaminants are in the surface of the water so that's where we should maximise the removal of dirt.
    Now in your first post you describe the situation standard and the situation as you have modified it. Your sensible ideas have improved the situation (note I do not say common sense as I doubt what is "common" these days)
    Water is incompressible so if you have a skimmer it should be matched with the same size in square inches of returns so 1 return for a skimmer is not rational, of course it will still work but the flow restriction from 1 return limits by definition the flow into the skimmer. I note you have 2 but you also have a big pump with a potential on high speed to still cause a restriction even with the M/D open because what come out the returns is what governs what flows into the pump. What kind of flow rate have you got?
    I don't go with small openings in returns to speed up the water flow at the exit as this is simply physics, and for every action there is an equal and opposite reaction so the harder and faster you push the water in the pool is trying to stop it and the restriction in the return opening is having a bigger effect up stream with a slow down in water flow and more strain and pressure on the filter gauge.
    If you do use the main drain to pull water for heating (what heater have you got that requires high speed?) and you send this out of the returns it still doesn't got to the bottom because it hot and less dense, it will float, sending the hot water into the pool from the M/D as a return does warm the bottom of the pool, does mix quicker and can cause any dirt to be lifted up into the mix to be skimmed out, you cannot get stuck onto the returning M/D and as you have stated this better flow with a main drain position (only returning the water will aid the skimmer performance and not reduce it. There should always be more than one skimmer although plenty of pools with only one do work, they work better with multiple skimmers and that can also handle the leaf load.
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by DennisP
    This forum and others are peppered with testaments about MD clogs and leaks. It is much more serious in an IG pool than an AG pool but still an issue that seems to be quite frequent. Given that every attribute that you assign to a MD can be accomplished in other ways, why have it? A MD is a little like an appendix, it serves no real purpose but it can be a real PITA when it goes bad.
    Quote Originally Posted by Teapot
    I have a little bit of a problem with this statement. You actually don't want the returns to have the same area as the suction ports. Pool plumbing is not the same as HVAC. If the return head loss gets too low when compared to the suction side head loss, the pump has a tendency to leak air into the pump basket and even cavitate. In general, you want the return head loss to be several times that of the suction head loss and restricting the returns with eyeballs is a good way to ensure that while still providing useful work.
    Plus return eyeballs serve another useful purpose. With higher exit velocity the water reaches more distant parts of the pool faster so mixing and circulation are a little better with smaller eyeballs. It does reduce flow rate but not by much and studies have shown (see sig) that flow rate and turnover are not all that important to pool sanitation and circulation. Also, the higher pressure does not cause more stress on the pump. In fact it causes less stress on the pump motor. Higher pressure means more head loss which in turn means lower flow rates and since a pump draws less power the further to left on the head curve (i.e. higher head loss), this also means there is less energy consumption and less heat to cause stress on the pump motor. It is also true that the efficiency drops a bit but if the run time is kept the same, the energy draw is still less, albeit less water is filtered per minute but again, I don't think that matters much.
    Mark
    Sep 2014
    Tucson, AZ
    Quote Originally Posted by mas985 View Post
    I can attest to this point with a example in my pool. I have a 1-1/2HP single speed pump (not happy about that) which drives my waterfall. The suction side is plumbed with 2" PVC and gets water from two wall ports in the shallow end covered with standard drain caps. The pressure side of the pump is split between two 2" PVC lines using a three-way Jandy valve. One line is 2" pipe all the way to the water fall (~75' or so) which is totally open at the water fall (no flow restriction, just an open PVC pipe). The other leg of the pressure side is 2" PVC to a wall return with an eyeball (I have plans to turn this into a pressure-side cleaner port someday). So, I can send 100% of the flow to the waterfall or 100% of the flow to the wall return or fractionally split it between the two.
    If I have more than ~ 30% of the pump flow going to the open pipe in the waterfall, the pump makes a horrible rattling noise (no air bubbles). I take this to be cavitation or close to it. I absolutely need the back pressure caused by the eyeball return to keep the pump quiet. I considered at one point in time installing a back-pressure regulator on the pressure side of the pump to regulate the flow better but a high quality 2" BPR in PVC costs almost $2000. So for now, since I'm not dropping money on a BPR valve, I just keep the Jandy turned mostly towards the wall return. I'll have to come up with a fancy manifold at the waterfall to restrict the orifice a bit and add more back-pressure to the pump. I consider it a pool builder design flaw...
    So I agree with mas985 that you must have properly designed head loss on both sides of the pump or else you risk premature equipment failure.
    mas985, I totally agree with you, it's a lot of your information that I have used in the past, you filter comparison chart saved me hours of work but and this is the big one! Why can't we run pools like HVAC system? I do, I have for 4 years. It's a paradigm shift away from the old idea of big power guzzling pump which when you take the head away will cavitate, complete agreement on that. Now I gravity flood my pump with below the water level placement so suction side headloss is low. the system pressure on the tank gauge is around .25 PSI when I am running slow (no swimmers and over night) and 0.75 PSI at swimming daytime running normal. I might get 2.5 psi when backwashing. The biggest difference is the power my setup consumes, slow running I move 1320 US gallons per hour at 30 watts of electricity. Daytime running 1981 US gallons per hour at 69 watts. this give me 4 turnovers per day or there abouts. The pump runs 24/7 to ensure any debris falling into the pool still gets skimmed out rather than sinking and the slower flow has meant water quality has increased, Previously without flocculation the water was around 5 NTU's still really clear to the eye but slower filtration brought this down to 1 NTU.
    On a bigger pool, my customers we have a bigger setup, that runs at 50 watts over night pushing 2588 US gallons per hour and 125 watts during normal times and pushing 3777 US gallons per hour. Technically he should run more to get 4 turnovers in 24 hours but he prefers to save the money and the pool water is still exceptional.
    In reality the old pool way is power hungry, wasteful and inefficient on filtration (the whole point of what we are doing)
    We really just want to move water from the pool, through a filter and back to the pool and that is simply what I do. The idea of producing excess friction to the point of loading the filter to 15 PSI normally is just some old dinosaur idea that has become the track pool builders run on but it's not required. The the big pumps we use are redundant and as you quite rightly say will cause cavitation if used on a highly efficient setup. Don't build the plumbing to suit the pump issue build the pump to suit the plumbing around the same as HVAC It will save $1000's.
    Do they? I have an issue with that statement and here is why. There are a few guys on Youtube (The slow Mo Guys) they fire an AK47 assault rifle under water in a pool. The muzzle velocity of an AK47 is 715 m/s (2,350 ft/s) yet in water the bullet travel 5ft. Instead I prefer to balance the size of the outlets to the plumbing and use the larger flow of water to move more water rather than a smaller faster (temporary) flow, It's like a locomotive at slow speed coming into the station, is bigger and moving slower but will destroy the station if it hits the buffer without the brakes.
    https://www.youtube.com/watch?v=cp5gdUHFGIQ
    I do agree with turnover rates etc, what is the point? you can turnover the water as many times as you want to pass some regulation etc but if the filtration isn't fine enough you are really just re circulating the small stuff. Chlorine has already killed the bacteria and those that are resistant and oocytes are too small to get caught in most filters so you may as well not bother and just fit a strainer at 30 microns. My filtration removes stuff to 4 microns so I am having an effect, I can use flocculation to remove even more. The need to run slower but keep moving is to ensure floating debris goes into the skimmer not to the bottom, that is why I sold my pool robot 3 years ago.
    Jul 2014
    New Berlin, WI
    Again, I fail to see any downside to a main drain... Clogs??? Really??? that does not make sense... I also fail to see why you would have any more leaks there than with any other fitting anywhere else...
    It all comes down to installation, plain and simple. In my case the pool is sitting on almost 2ft deep worth of crushed limestone that extends 3 feet at least that over the edge of the pool in all directions. The main drain piping is buried in compacted crushed limestone along with the main drains themselves and the connecting tee section being buried in quick set concrete too. There is no way the main drains are moving, settling, changing, etc...
    So, yeah, go ahead and bemoan the whole main drain issue all you guys like, but it is fact that cooler water gets pulled into the main drain thus causing quicker heating and overall better mixing within a shorter timeframe. To say otherwise is being obtuse. Sure you can argue that you can aim returns, use lower on-wall suction points, etc, etc... fact of the matter is water in on the sides aimed to swirl the pool and water going out the skimmer as well as the main drains will maximize the mixture way better than using a skimmer alone. To argue anything else is just being foolish and goes to show a bias against main drains for a whole host of reasons other than what I have stated.
    Honestly, I am sure there are a bunch of people that have had loved ones hurt or killed by main drains, and I don't hold it against them one bit to try to get them removed from everyones pools because they truly don't want anyone else to go through the pain and heartache, and it is almost fanatically obvious that is the big slant against main drains in general. But, with dual drains, and keeping them cut in along with the skimmer, the possibility of entrapment is nil.
    As I said before, from a pool professional standpoint they are a nightmare to install, to repair, to deal with. As a installer/maintainer I would much rather deal with stuff that is affixed to the sides of a pool, honestly ANY pool (be it above ground or in-ground) instead of having to deal with the floor and a main drain. But, personally, as the person that installed it, and the one that will maintain it, it just makes far more sense to have it in the bottom than to have other crap drilled into the walls. Heck, I am kinda sorry I put an extra return in. It works well, but looks just as you would expect, with it being an eyesore. I am probably going to try to cover it up at some point with a statue, or plants or something... And that return is a solid white 1.5" PVC pipe coming up from underground to the elbow and into the pool, so it isn't like it is ugly hoses or anything else that would detract, but it still looks unsightly.
    mas985's Avatar
    Pleasanton, CA
    You don't necessarily have more incidents with a MD than a skimmer but it is far easier to fix a skimmer leak or clog than it is a MD. I have seen many POs that think it is a good idea to use their MD for spring clean up and create a massive clog.
    So I guess I am going to have to be foolish again as I have solar and have measured temperature differences from the surface to the deepest end (9') and saw no difference in temperatures with or without the main drain (I have one return that is pointed into the deep end). It really doesn't take much to mix up the water and almost any return is sufficient unless the pool is really deep.
    What I really meant by that is that an HVAC fan will do fine with equal friction loss on both side but a pool pump will not. But I bet if I did a head loss calc on your setup, the head loss is not exactly the same on both sides of the pump and therefore the two sides are not exactly equal. If they were, you would probably have cavitation at higher RPM. Low RPM doesn't matter because the pump cannot cavitate on lower speeds.
    Also, a PO on another forum thought he was being smart and energy efficient by running a separate line for every return (i.e. keep the pipe size AND ports the same on both sides of the pump). Combining that with a low head loss cartridge filter and the pump was cavitating severely. The only options for him was to either throttle the return with a valve or down size the eyeballs. At least with the latter, the higher exit velocity does some useful work while throttling just adds head loss.
    A bullet has far higher density than water and so it will sink before reaching the other side. Higher exit velocity of water will simply move in a straight line and the faster it moves, the faster it will get to the other side. One way to make a spa jet feel stronger is to use a smaller orifice spa jet which increase the force per unit area. When I changed my return eyeballs from 1" to 3/4" and I saw a noticeable difference in debris movement to the skimmer on low speed. However, there was only about a 1/2 PSI rise on pressure but I do have 4 returns. The smaller returns make the flow more directional but it also helps to move the surface water better at lower RPM for better skimming action. If the larger eyeballs are working for you then fine, use them. I was only saying that the smaller eyeballs can have benefits for certain situations.
    Mark
    Jul 2014
    New Berlin, WI
    And here we have it... You are talking apples and I am talking oranges...
    Basically you are in a warmer climate, I am in a much colder one. I am looking to warm a pool from 45 to 90+ degrees in the shortest time possible. I don't have time to allow solar to do the work. I am using a 250k BTU heater and paying for natural gas. I am needing the pool heated the quickest, without exception.
    You are heating a pool via solar, probably with the pump on low, but even on high, no big difference. Solar will not generate the heat a 250k BTU heater will unless you have a huge solar unit and/or it is already pretty warm out were you are at. I have neither convenience. I am in a worst case scenario.
    Like I stated, I know main drains work much better. I have ran the tests last year. There is a huge difference in general with the pool running with and without the main drains, in all scenarios. I outlined everything above. These are all real-world observations in my setup. Like I said it is amazing you guys will all argue it when I have posted exactly what I have experienced.
    I am also above ground, you are in ground. Outside air temp affects my pool not only on the surface, but on the sides as well when the temps get below 60 degrees, even worse below 50 degrees.
    Again, the arguements here are based on a "study" that is obviously a campaign to get rid of main drains because someone got hurt and the people performing the study have are on a crusade. I could care less how much debris they pull in. I care about all the advantages I have seen personally.
    It is amazing how polarizing a single topic like this is. And again, usually the ones advocating not having one, actually have one. How ironic. It is also amazing how far you guys go to try to "prove a point" when you ignore anything else anyone has to say. This isn't like arguing about water flow in piping (which is 100% purely engineering on all facets), there are tons of factors that get involved that are specific to any given installation. I already said many times I understand why the "pros" don't want to deal with them. If it is that, then just say it is that and move on. The rest is so unbelievably ignorant it is hard not to tell you guys you are all being stupid, since you are. I already have the main drains in. They are not going anywhere. Take into account EVERYTHING I have stated and it is quite obvious I am beyond happy I went this way. Just come right out and tell everyone that you are advocating they DO NOT go with one because it is YOUR OPINION. And, please, be adult enough to explain why that opinion exists, regardless if it is a matter of, "I think they are a hazard" (the fear factor), or, "I don't see how they can help" (the ignorance factor), or, "in MY case they don't do anything for ME" (the apples and oranges factor), or at the least, "I don't ever want to deal with the massive PITA a main drain problem is because I maintain others pools" (the pool professional factor)...
    But again, it is more a matter of everyone trying to convince everyone their opinion is better, since it is just a matter of fact that when you are pulling water from the lowest, coolest location that is the furthest point away from a given return that is located nearer the surface and aimed to the side, that you are maximizing circulation. To argue that is just showing how ignorant you are being.
    mas985's Avatar
    Pleasanton, CA
    Really? You have to hurl personal insults to prove your point? I guess you have to attack the messenger because you can't argue the message.
    Mark
    Yes that person's idea was floored, not really from the plumbing point of view except the single lines for the returns is way too much as any flow calculator and headloss calculator would show but the issue is the wrong pump. We think pool, we think pool pump we buy off the shelf without thinking the issue through. Baring in mind I don't run the pump fast except for back washing cavitation isn't an issue. I have a slow start mechanism for the pump to build up to speed which is better than 0-2800 rpm but in the main the filter provides sufficient reduction in flow to prevent cavitation with the slow start and reduce power I use. At 30 watts the motor RPM is 1400, at normal pool speed 1800 RPM (69 watts). I agree they are probably not exactly the same but close and no cavitation as the power being used is controlled, unlike so many of the variable speed pumps that start with a burst of maximum RPM to prime presumably, I try to work with nature and not against it.
    Yes the bullet does but it also has a way higher velocity, it's path decays so quickly as the water put's up an opposing force (Newton's 3rd law of motion). I agree the directional flow does help so adjusting the size to suit is necessary. The flow doesn't move in a straight line though, it forms a turbulent street shedding it's power as it goes. It may move in the general direction but the turbulent flow helps mix the chemicals rather than pushing a jet of freshly chlorinated water into the skimmer which could upset the chemical redox probe. I too have 4 returns on my pool, another much bigger had 7 and 3 skimmers, that really got the water mixing and near no dead spots. My point about the eyeballs is they are crap from a fluid design perspective as they don't smoothly transfer from one diameter to another, there are shelves and steps everywhere so more back pressure is applied to the flow. I too use the smaller eyeballs where necessary but the total area of all the holes is near equal to the area of the pipe/s delivering it and the eyeballs are taper machined to the right size to achieve the best result.
    My spend on electricity per season is around $32 at the current euro/dollar exchange rate. I refuse to go back to old ideas by old pool builders who say I have built pools for 30-40 years but really they haven't learnt a thing in that time they just repeat 1 years experience 30-40 times.
