Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 35
Thread: returned and pool completely cloudy
    Default returned and pool completely cloudy
    added 4 each 3/4 gallons of bleach to pool when left on Wednesday. Returned today, no chlorine, ta 180, ph 7.5,cya 45 pool completely cloudy, cannot see the bottom anywhere. trying to hurry and beat the heavy rain that is starting...i just now added 6 each 3/4 gallons of bleach to the pool . please advise to help me clear this mess up! thanks.
    Default Re: returned and pool completely cloudy
    You should keep Cl 12-15 ppm to clear up any algae that's taking hold. I'd add at least a half bottle of clarifier. HTH brand from walmart or elsewhere and keep pump running. Once it clears, vacuum bottom to remove junk and you're set.
    Do not add clarifier unless nothing else works.
    Keep your chlroine levels up to suggested levels, your pump running and have patience. You need to kill the algae (that's what you have) and then get the dead algae out. Clarifier doesn't do either.
    There is no magic bullet for cleaning up pools that have an algae bloom.
    Thanks for the reply. i will keep adding the bleach and hope it works. i was having a problem before i left that it still stayed a little cloudy even when i kept shocking it. just couldn't clear it completely up.... do you think it's cause i didn't keep the levels where they needed to be?
    Yup.
    That's why we keep harping on proper and frequent testing. I test my water several times a week, and do a full test each weekend:
    Yesterday,
    19,200 gallons vinyl
    78 Deg F.
    FC: 6.0ppm
    CC: 0
    TC: 6.0ppm
    pH: 7.5
    TA: 90ppm
    CYA: 30ppm
    CH: Only test 2 or 3 times a summer
    Week before:
    79 Deg (little sun, lots of rain)
    FC: 1.5
    CC: 0
    TC: 1.5
    pH: 7.6
    TA: 90
    CYA: 30
    CH: 70
    So, even though the water was clear and perfect, I KNOW that for CYA=30, I should have at a minimum, FC=3.0.
    I also know that 1 gallon of regular bleach(5.25%) adds 5.25ppm of FC to 10,000 gallons. My pool is virtually the same as 20,000 gallons, so 2 1/8ppm would be added--that put my FC over 3.5--back in the good range, BEFORE a problem began.
    Later in the week, after tons and tons of rain, the FC dropped again, so 2 gallons of bleach went in late in the week, resulting in Sunday's numbers, which are about as good as I can get.
    i do test my water everyday and add as i am suppose to, i think, i hope.. but when there is a problem and you have to shock and try to hold it at shock level until it clears...that's hard for me to do when i work. i can't test it 3 or 4 times a day and i guess that's where my problem is that i'm not holding it at shock level and i didn't get it completely clear before i left....i have learned that from you and the others on this forum...but i am trying and i do appreciate you bearing with me and my mistakes and in helping me get on the right track. thank you Carl D.
    What is your Ca level? Have you been using cal-hypo shock? If you Ca is high, and TA are high, you may be having some precipitation problems.
    I'm with CarlD, though--keep the bleach to it, skip the clarifier!
    not sure what my ca is. i added 4 each 3/4 gallons bleach on sunday night and 5 each 3/4 gallons bleach last night. this morning chlorine was 10-12 so i added one each 3/4 gallon. there is no change at all in the pool since i started this on sunday. please advise what else i need to do???
    Like stated before, keep the Cl up and pump running. And their right, at this point the clarifier won't help, as it's only a flocculant for sinking floating gunk. Seems like your cya may not be stabilizing Cl long enough for it to do any good....but 45
    cya should be good. I'd vac to see if that helps while keeping Cl to shock levels. You may want to get water source checked for anything unusual that may be causing this?
    Downingtown, PA
    This process of keeping the pool at shock level could take all week. Make sure you backwash/clean filter as necessary.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
  1. Also in Louisiana, COMPLETELY new to pools
    By R6 Guy in forum In-Ground Pool Construction and Repair
    Last Post: 08-04-2012, 06:47 PM
  2. From cloudy green to cloudy blue
    By Dydylynn in forum Dealing with Algae & Slime
    Last Post: 06-10-2012, 06:09 PM
  3. Problem removing algae completely
    By nancybram in forum Dealing with Algae & Slime
    Last Post: 07-17-2011, 06:47 PM
  4. completely confounded by air, prime problems
    By salinda in forum Pool Equipment & Operations
    Last Post: 06-03-2006, 11:52 AM
