Results 1 to 9 of 9
Thread: Accurate test results
    Pamsel is offline Registered+ Thread Analyst Pamsel 0
    Central Illinois
    Default Accurate test results
    I'm hoping someone can help me with this. Two days ago I took a water sample in to the one pool store in the area who is supposed to do accurate water testing. I wanted to have it tested for metals, since I can't test that.
    The test results were so vastly different than my numbers with my Wal-Mart drop kit, that I am really unsure which is accurate.
    My TA is still high ~ tests in the 320-340 range at home; the pool store test showed 210.
    My CYA tested 25 last week, theirs showed 0.
    When I test for hardness, the kit says that when I add the hardness indicator, the water should turn red if there is any hardness. My water turns a very slight yellow-tinted clear. The pool store test says my hardness is 367.
    Their test showed no iron and .2 copper, even though I know that the water I top off with is high in iron and I had overdosed it on copper algaecide about 3 weeks ago. I have put a sequestering agent in 3 times since then. Would this account for the test showing no metals?
    Also, when I use the dilution method to test my CL, I don't seem to get accurate results either. I am using reverse osmosis water, rather than distilled to dilute with. Would this make a difference? When I test without dilution, my color is deep yellow - almost yellow-orange. But when I dilute and multiply, it comes out to 6-7 ppm, which I know is not correct. What am I doing wrong?
    Thanks for any help!
    Pam, Illinois
    "17'x33' oval 14.5K gal IG vinyl pool; liquid chlorine; Hayward Pro Series, M-S-244T sand filter; A.O. Smith Centurian, Switchless, 1.40 HP pump; Right now 24/7hrs; Pool Solutions PS234
    Serial #6511, Drops / Powder; Community well; summer: none; winter: mesh; ; PF:8.3"
    Default Re: Accurate test results
    Use steam distilled water--every big drug chain and most supermarkets have it. Reverse Osmosis is a technique for making sea water drinkable, but cannot be used in polluted areas, like bays and harbors, only on the high seas. It's basically a portable de-salinator.
    Quote Originally Posted by CarlD
    Reverse osmosis removes almost all dissovled solids from the water. If it is followed by carbon filtration it then removes soluable organics and chlorine from the water.
    Central Illinois
    I don't know what kind of test system the pool store used. They are an AquaBan store. They used a test strip that they dipped in the water, then put on a little tray that slid into a machine that came up with the readings. There were no small plastic vials with powdered reagents.
    Their test also said that I have no more algae, which I am not sure is accurate either. All I know is that the appearance of my water has remained basicly unchanged for two weeks, in spite of everything I have done to correct it. It has been a little less cloudy a day or two but when I brush the pool it stirs everything up off the bottom and sides and the water becomes totally dark and cloudy again. It doesn't seem to get filtered out or cleared up by exposing it to more CL.
    Pam, Illinois
    The are using test strips with a colorimeter. This is similar (or possibly is) the Alex system by Bioguard.....Run, don't walk, to a different pool store for your tests....Based on this info I would trust your Aquachem results over theirs!
    Central Illinois
    Actually, I think I posted that wrong. I believe they are a BioGuard store - not AquaBan. They actually call themselves "your accurate water testing center"! The other main pool store in my area only uses test strips - same as I used to use at home. All the other stores in my area are either branches of these two, or very small stores. I'm going to have to search the yellow pages and call around. I may not have a place to get my water tested accurately.
    Pam, Illinois
    First, test results are only as good as the people doing the tests
    Second, they are only as good as the test kit used.
    I cannot comment on either your or the pool stores testing methods but I do know this. The CH on the walmart Aquachem kit does have some problems. The indicator turning yellow has been documented by myself and others in a different thread. Sometimes this test works fine and sometimes it doesn't. I suspect that high chlorine levels are causing the interferance.
    The copper and iron results you got mean that the sequsterant you added had worked and made the metals in your water non reactive or that the testing procedure is not correct.
    If the pool store is using LaMotte testing (small plastic vials of powdered reagent injected with pool water) then I can explain the low TA readings. The TA test needs to develop for 1.5 minutes and needs to be read before 5 minutes has elapsed. If not it will read low. (It will also read low if the chlorine levels are above about 6 ppm but it doesn't seem to really affect the test until the chlorine gets to about 9-10 ppm) Ditto for the CYA test except it needs to develp for about 2 minutes as does the copper test. The iron test is supposed to develop for 3 minutes before reading. Also the LaMotte test is a total hardness (calcium and magnesium hardness) test and not a calcium hardness test.
    If they are using a different test chemistry then I really don't know except that some pool store water testers really don't do a very good job with their testing.
