It looks like your numbers are at least close to the pool store except for alk & hardness which are WAY off. I would be a little suspect of your numbers. Is your hardness really 0 ? In a exposed aggregrate surface that seems unlikely. I would tend to believe the pool store hardness reading of 185 then I would 0. Test your tap water is it 0 ?
And for the TA of 300 vs pool store of 120 I would double check my tests before putting a bunch of stuff in your pool to increase hardness and alk becuase if your numbers are wrong then it will be tough to correct. It seems in your subsequent tests your TA was really bouncing around radically. Is your test kit old ?
-- john
I think the reagents for TA and CH are older than the rest. I need to get a new test kit. My TA readings keep decreasing, while my pH keeps drifting up (even with constant additions of acid). I may go back into the pool store tomorrow and get the water tested again. I need to get my CYA tested because we added last week, but I"m out of reagent.
