I had a similar problem with the CH test in the WalMart (HTH) 5-way test kit. My TC was in the 3-5 ppm range at the time and the hardness was actually pretty low (10-20 ppm) but the solution turned yellowish when I added the 5 drops of the dark reagent. The CH test in Ben's kit worked without a problem.
Peter
