Cloudy Water - Cartridge Filter - Test Results
Ok, I had my father go and get the water tested. Just some information, I have a 12X18 Oval above Ground pool. 5 feet deep. I have a brand new Cartridge Filter, and 1.5 HP Pump. The results are as followed:
TA - 60
PH - 6.3
CYA - 0
Total Hardness - 140
TC - 4.4 (recently shocked)
Now the water has the whitish/blueish cloudiness to it. If I put my hand in the water, I can basically only go up to my wrist before I can't see my fingers in the water. I am currently increasing the TA and PH to normal levels. Any other suggestions to help clear the water would be appreciated!! Thanks so much!
