Re: Cloudy water- Cartridge Filter
I'm picking up a drop test kit tonight as well as a stabilizer, and more bleach. I'll do a test, and report the results this evening for you. I'm not sure how much of the bleach held in the pool today. I added 3 Qts. this morning, however its been sunny and in the 80's all day. With no CYA, I assume the chlorine will dispurse fairly fast. I should still hold off on adding the CYA till I get the pool clear correct? Also, would you recommend a good vacuuming tonight, or do you think I should wait till I can see the bottom of the pool??? Thanks!!
