Re: Cloudy water- Cartridge Filter
Ok, I tested the Chlorine this evening and it was about 5ish. I added more Bleach this evening. I also gave the pool a vacuum. When I did that though, it seemed to stir a lot up. There were lots of white foamish stuff everywhere on the surface. Is that due to the bleach, or the previously entered chemicals from last week? When I was done vacuuming, the pool was just flowing the white foamish stuff straight through the filter and back into the pool. This is really frustrating. I just want to make sure that I continue to keep the Chlorine level up as much as possible. It still doesn't look any different from this past weekend unfortunately.
