Results 1 to 10 of 18
Thread: Bad bearings or something else
    Default Bad bearings or something else
    Pump is about 4 years hold, and this is the sound it makes, which it has been making for about 4 years now and my neighbor just told me it doesn't sound right.
    https://www.dropbox.com/s/6l3cpxdclr...71539.mp4?dl=0
    It's an Emerson 1HP... bearings? Can parts be found for these or do I need to replace the entire motor?
    Jul 2013
    Northern Illinois
    Default Re: Bad bearings or something else
    Hmmm. Not a mechanic here. Do I see lots of bubbles in your pump basket? Are they always there? Impeller comes to mind.
    an impeller would make that noise?
    bubbles are always there, been like that for 10 years.
    Jul 2013
    Northern Illinois
    Not sure about the impeller but it doesn't sound right to me. Waiting for an expert to chime in here. Things are a bit slow this time of year.
    You have had those bubbles for ten years? That does not look normal to me. I will see if I can get someone to help.
    The bubbles don't bother me so much. I tried tracking them down, replaced the 3 way sandy valve rings, replaced the clear top, the top o-ring and it still bubbles. It doesn't bother me.
    The noise, however, is bothering my neighbors so I want to fix that issue. My gut is telling me bearings, but i never thought of the impeller. I guess I could disconnect/remove the impeller and just run the motor with it not connected and see if it's just the motor making the noise?
    Jul 2013
    Northern Illinois
    I really know nothing about motors! I tried to get some people to look at your questions. Hope they do!
