Re: Need help! Please!!!
Thanks for the help.
A few more questions...
So, does that mean that I need to add 2.5 - 3 gallons of bleach tonight?
Test/add bleach (as necessary) each morning/evening thereafter?
The pump's been running 24/7 for a couple weeks.
Is it worth buying a vacuum head/hose? Would it speed up the process?
What effect will the additional chlorine have on the grayish/greenish dust? Will it just "go away"? Or, should I brush? If so, how often?
I guess I'm just impatient because I haven't seen clear blue water in a LONG time...
As far as test kits, I have an hth drop kit from last year. Do those things have a shlef life? Should you buy a new on each season?
Once I get this cleared up, I SWEAR to follow the 3B method...
THANKS!!!
bgray
