Re: Need help! Please!!!
Hmmm. You seem to have lost faith that Cl will clear your pool. That's your call.
I can offer no other remedy. Partial draining may temporarily clear your pool and it may get it good enough so your filter can finish the job. The pool water that you do not drain will still be contaminated, however, and, unless you use Cl, I can think of no way to keep it clear on a permanent basis.
