Hi, Sandy,
Those numbers look great! Nice Work.
Alk is fine...I count mine when it turns truly pink/red but 10ppm is not critical either way.
I would recommend 40ppm for CYA. That should hold your consumption down and allow you to go higher later if you choose. The container of CYA will tell you how much to use.![]()
