Results 1 to 10 of 19
Thread: Reduce Chemical Usage 30-50% while stabalizing pH ;-)
    Downingtown, PA
    Default Reduce Chemical Usage 30-50% while stabalizing pH ;-)
    How is this not in every pool in America with a price tag of ONLY $59.95!!! No electricity needed, no replacement parts...
    **Plz no red, I realize this is going to do as much as clipping a potato chip bag clip onto my PVC pipes.**
    http://www.poolmart.com/magnetizer.asp
    A simple and effective patented magnetic water conditioner is now available for your pool. Laboratory tests prove that by simply strapping the Magnetizer on the return line to your pool, the Magnetizer reduces sanitizing chemical usage by 30% to 50% while stabilizing pH and eliminating all pH chemicals, thereby saving you money. The Magnetizer helps to eliminate algae, keep water clean and improve the clarity of your pool.
    How does it work?
    As water molecules pass through the powerful and highly focused magnetic field, the Magnetizer Pool System does two things: Polarizes (organizes) molecules and gives water a net positive (+) charge. This physically restructures the water making it provide all the great benefits described below.
    How it Works
    Magnetizer Conditioning
    Magnetized water produces the benefits of soft water. It also magnetically locks the chemicals into the water resulting in:
    Reduced chemical eye and skin irritation
    Reduced obnoxious chemical odours
    Luxurious silky feeling
    Reduced Chemical Costs
    Bromine, chlorine and other chemicals used in your pool maintenance mix more completely and effectively in magnetized water. The reduced surface tension and the increased ionic activity of the magnetized water helps to reduce operating costs as well as reducing chemical needs.
    Stabilized pH
    pH is the balance between charges in the water. Wide variations in pH will damage equipment while frequently reducing the effectiveness of the chemicals. By magnetically organizing the water molecules, the wide range of the pH swing is reduced, as is the need for chemical usage.
    Improved Filter Performance
    The positive water charge pulls skin oils and tanning lotions into the water allowing them to be removed by the filter. The result is a pool that is almost self-cleaning.
    Remove Scale
    The Magnetizer Pool System puts a positive charge into the water. This not only stops scale build-up, but dissolves pre-existing scale deposits. This scale removal protects equipment and allows heaters to operate at peak efficiency, thereby reducing energy dollars.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    duraleigh Guest
    Default Re: Reduce Chemical Usage 30-50% while stabalizing pH ;-)
    Yeah, but I'll bet it causes alzheimers or cancer!
    Arizonaoldman is offline ** No working email address ** Arizonaoldman 0
    Bullhead City, Arizona
    You know, I have a friend who has something similar to this installed on his house water. He swears by it and I've done enough research to thoroughly confuse myself. On the surface, if you believe the claims, it looks like a pretty good deal. Then the question previously asked, "Why aren't these installed on every pool?" That little voice in my skeptical mind keeps saying, "no way."
    Ralph
    mbar's Avatar
    Ashland, PA
    hmmmm, I read on a website that fiberglass has a negative charge, and may be one reason that it stains. I would love to know if this works. Anyone else with any ideas on this?
    Northeast PA
    Central Texas
    I keep an aquarium and participate on aquarium forums. The water magnetizer comes up for discussion on a regular basis. Each forum has its 'science guys' and the consensus is always that it's a scam.
    The other one is the Plotcher system where little sticks 'remembers' good water and then 'tells' the bad water how to behave...
    TW
    Downingtown, PA
    Quote Originally Posted by aquarium
    TW
    Now that sounds like something I could get behind!
    mbar's Avatar
    Ashland, PA
    Ha, ha, good water, bad water! I was just hoping that it was something that wasn't just snake oil. Never hurts to ask!
    Northeast PA
    Scottsdale, Arizona
    Install the Magnetizer on your carburator and you'll get better gas mileage as well
    Central Texas
    Here's a link to a guy that debunks one made for aquariums, the claims for the one made for pools sound very similar.
    http://www.rexgrigg.com/debunked.htm
    TW
    Been keeping aquarims for close to 45 years now (salt for past 30) and everything I have ever seen about magnets seems to scream SCAM! They have never stood up under serious testing....and aquarists are very much into testing things when they are really into the hobby!
    I seem to remeber reading something about magnets on the old forum. I think it was posted by Ben (PoolDoc). It was not positive.
