Re: unable to unscrew SWG for cleaning
phillipjko
I tried everything to open it. The Pipe seems 'stuck' I use a large size tool to try to pry it open but decided againist too much force as I did not want to risk breaking the pipe and redo again. I use the Calcium lime remover but that did not budge. Advise?
What kind of SWG is it? Are these just standard PVC screw-on unions?
If find for PVC screw unions that strap wrenches work the best. They conform to and grip the typically irregular surfaces of the threaded union nut and give you a lot of leverage without metal jaws gouging into the plastic. If you have two of them, it's typically really easy to undo even the stiffest unions.
Hopefully the unions are not cross-threaded and/or the threads stripped. If you do get it off, it's always best to use liquid teflon thread sealant, not teflon tape, when closing it back up again.
