Results 1 to 4 of 4
Thread: pool heating
    Aug 2012
    Central Florida
    Default novel method of pool heating
    We gave up our gas heater just before winter, as beachfront wear and tear rusts them out regularly. After a winter of being unable to use my pool (just too cold this winter in central Florida), I am anxious to investigate alternatives for next winter that would wear better on the beach.
    I came across this idea online: someone took a truck radiator, painted all the fins black, and put it where sun shines most of day. A 1/2 inch line was put on the discharge side of filter pump and run through the radiator. A faucet (I assume that means a valve) was put on the line to reduce or stop the flow. This method was used on a 20' x 40', 11' deep end pool in the midwestern US. They stated that it heated pool so well it often had to be shut off. Even on a a cold sunny day, like late September, it warmed the pool enough (82 to 84 degrees) to last for late night swim. The owner also had a gas heater, and stated he seldom had to use it as a booster to the home-made system.
    It's much warmer here in central Florida (with lots of sun), and this seems a simple, elegant, and low cost way to warm up my pool in the winter. What do you think?
    20x40 rectangle 28K* gal IG concrete pool; sodium hypochlorite; Hayward Star Clear 1200 (2) cartridge filter; SR 2.5 hp 1 speed pump; 6 - 8 hrs; gas heater, spa, fountain or waterfall; All-Clear 2-way test kit ; Taylor 2006C; utility water; summer: none; winter: none; none; PF:4.3
    Jul 2010
    Largo, Florida
    Default Re: novel method of pool heating
    Lots of folks have success with DIY solar. Most thread I have read involve using black hose to pump the water through. Seems like a radiator should work too, but it's metal so as it corrodes it might add metals (and therefore stains) to your water.
    Here's an example thread: http://www.poolforum.com/pf2/showthr...ar-pool-heater
    mas985's Avatar
    Pleasanton, CA
    A radiator is very small area compared to the volume of a pool so I don't think it would add much heat at all. The numbers don't add up. It is all about surface area with solar. Don't believe everything you read on the internet.
    Mark
    Jul 2013
    Northern Illinois
    Yea.... I am buying a new heater this year... Wish there was a good alternative. Can live with 'em, can't live without 'em...
    26K gal 20x40 rectangular IG vinyl pool; Apr 2014: New pump, liner, auto-cover, & water; Pentair Whisperflo 1HP pump; Pentair Trition sand filter; Cover/Star CS-500 auto cover; Taylor K-2006C; OTO
  1. Heating advice for pool in the UK
    By Volleysi in forum Pool Equipment & Operations
    Last Post: 08-11-2013, 06:45 PM
  2. Pool Heating
    By Chalky in forum Pool Equipment & Operations
    Last Post: 08-29-2012, 09:41 PM
  3. Solar Heating for the pool
    By rnaval in forum Pool Equipment & Operations
    Last Post: 09-11-2011, 10:23 AM
  4. pool heating-what i've learned that may help you
    By tenax in forum Pool Equipment & Operations
    Last Post: 09-03-2006, 02:51 PM
