Chris, as you are a senior member, I doubt that I need to remind you of the CYA increase, if you use pucks. The other thing is your saying that you'll only run the pump durring the day to prevent freeze up - I'm also in Ct. and the daytime temps are well above freezing now, so perhaps you meant to say you'd run the pump only at night to prevent freezing. Your water hasn't reached 50 deg. yet ( I know, I'm just starting to open up pools and the water temps are lower than 50Originally Posted by chrisexv6
) However, the water temps are a little more comfortable every day and I think you are doing the best thing for your pool by adding chems and circulating the water now - at this time of the year, a minimal dose of cl and a few hours of pump run time will save you many headaches - as opposed to waiting until the water was temperate enough to swim, and then trying to get it ready for a weekend swim party
