Re: First Spring with a SWCG (repeated from another thread)
Yeah, that's standard Pentair IntelliChlor boiler-plate. They updated it a bit as my older manual says the CYA should be no more than 50ppm. And I love how they say to use Super Chlorinate mode to remove CC's...don't waste your time and electricity as SuperChlorination does very little. All it does is run your IC for 24hrs straight at 100% power. The net effect is only a minor rise in FC and MAJOR wear and tear on the cell plates. Better to remove CC's by simple bleach chlorination at shock levels. As for phosphates, it is remotely possible that you can form calcium phosphate precipitations if the phosphates levels are ridiculously high BUT the water chemistry has to be so far out of balance that other problems will manifest themselves way before calcium phosphate scale ever becomes an issue.
So I agree with @kelemvor except that I add powdered stabilizer (CYA) by placing 1 pound of it (16oz) into a nylon skimmer sock and tie off the top. Then I either hang the sock in front of a return, float it in a blue chlorine puck floater or put it in the skimmer basket. That way it can dissolve slowly and not clogged anything up. Also, powdered stabilizer is very acidic and will lower your TA so if you do use the sock method in the skimmer, only do so while the pump is running. If the pump is off, remove the sock from the skimmer and put it in a float. You do not want a large amount of CYA sitting in a small volume of water.
