Re: Chemicals Required to Open Pool
jmarcum
I should have mentioned that I do have the 3.5" tablets in my pump.
As in 3" stabilized chlorine tablets?
I forgot to take note of the fact that you have an ozonator hooked up. I'll stay away from the "politics" of ozone generators and stick to the facts that the added ozone explains why your FC is low, your CC's are 0 and your water is clear. O3 is good at oxidizing the combine chloramines but it's efficacy as a disinfectant in a residential pool is debatable (spas and hot tubs with ozone are a completely different story).
That said, I'm not entirely sure how to help you. Normally in a pool like yours, you'd want to target a CYA level of 30-50ppm and an FC in the 3-7ppm range. At 35ppm CYA your minimum FC should be no lower 2.5ppm. I suspect the ozone system is allowing you to maintain a lower FC and not have an algae bloom but you are walking a fine line between clean and green.
Also, putting chlorine tablets in the pump is not really a good idea. They should be used in a floater. Chlorine tablets are basically 99% trichloroisocyanuric acid (thrichlor) with the operative word there being ACID. Tablets are very acidic and can lower the pH of water quite a bit. So, when your pump isn't running, the tablet is slowly dissolving and the water inside the pump is becoming very acidic. That can do damage to the pump over prolonged periods of time. As well, trichlor pucks add CYA to your water so that, over extended periods of use, the CYA level of your pool can rise to high values causing the FC to become less effective (typically CYA > 100ppm makes it hard to stay sanitized).
Perhaps some others might chime in soon. I don't have a lot of experience with ozone in pools and the values you may want to target could be quite a bit different from chlorine-only pools.
