Results 1 to 10 of 41
Thread: A picture is worth a thousand words . . .
Threaded View
  1. #21
    Default Re: A picture is worth a thousand words . . .
    VERY IMPORTANT!!!!!!! DO NOT TRY AND TEST OR AJUST YOUR pH WHEN THE CHLORINE LEVELS ARE ABOVE ABOUT 10 PPM. YOU WILL GET INTERFERANCE AND A FALSE HIGH pH READING. From two of your posts above:
    CL 14-15
    PH 8.0
    and
    CL 6.0
    PH 7.8
    Sorry for shouting like that! Here are my thoughts, I could be wrong.
    The green color does look like copper, even with the sequesterant you might be oxidizing the copper with the high clorine levels. I think the stuff in the pool is dead algae now and the filter is not taking it out for some reason. What kind of filter do you have? You might want to make sure it is working properly. Is the pressure reading normal? If it is a sand filter you might have channeling in it. You can clean the sand if that is the case. If it is a sand filter you can also add a bit of DE to it (enought to raise the pressure 1psi) This can help it filter out the finer stuff. Try letting the chlorine drop to normal levels and hit it with a seqesterant again. Jack's Magic Blue Stuff is designed specifically for copper. You might want to try that and see if it clears the green. Get your chlorine and pH levels to where the bottle says before treating. If it works THEN lower your TA!
  1. How would you backfill this (picture included)
    By idohair2 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-27-2011, 11:43 AM
  2. Pool Planning Picture - Feedback sought
    By skijunkie in forum In-Ground Pool Construction and Repair
    Last Post: 03-02-2011, 03:47 PM
  3. Where to blow out line (picture)
    By Charrua2 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-10-2006, 06:08 PM
  4. words of encouragment!
    By ILHoz in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-21-2006, 12:03 PM
  5. Picture of S 244T Hayward Valve Control?
    By LennPrice in forum Pool Equipment & Operations
    Last Post: 07-05-2006, 10:09 PM
