Results 1 to 8 of 8
Thread: Robotic cleaner recommendations
    Parker, CO
    Default Re: Robotic cleaner recommendations
    Quote Originally Posted by ekalbs4 View Post
    I've researched most of these same models, and like you, I've eliminated several because of the weight. Have you looked at the Dolphin Triton? From what I've read, it is supposed to be similar to the Pentair Prowler 830 and the Dolphin Premier and Dolphin DX6, however, it is only supposed to weigh 19 lbs. About $300 less that the Dolphin Supreme M5/Dolphin Oasis Z5/Dolphin Triton Plus.
    I found the information on this website to be very helpful to identifying which units are similar, but with different branding,
    http://www.sunplay.com/blog/the-trut...t-telling-you/
    Interesting info. Didn't know there was a third cleaner that was similar to the M5. In doing a quick study, I still paid less with the rebate. I'm also finding that "specs" vary from dealer to dealer. Weights, suction rates and warranties differ from the manufacturer to dealer to dealer. All very confusing.
    I did look at the Premiere and DX6 and the Nautilus, but leaned toward the Supreme series for one reason or another, handles, ease of cleaning, replacement of parts, etc... I set my criteria's and looked at a ton of reviews and websites.
    36'x20' Freeform, IG - 13k gal, Spa - 800 gal, Diamond Brite, Intelliflo VS pump, TR-140C sand filter, Mastertemp 400k BTU heater, 2HP Whisperflo pump (waterfall), Pool Pilot Digital RC-42 SWCG, K-2006 Test Kit
    May 2014
    Ontario, Canada
    Over the years I have tried 3-4 of the pump type Kreepy Krauly or others.
    Last year I bought an electric Maytronics Dolphin Supreme M4. This thing is incredible, it cleans easily, will pickup leaves and just about any dirt in the pool. Best thing I ever bought for my pool and it work perfectly from day 1.
    No need to run my pump more than 6 hours a day now.
    http://dolphinpoolrobot.com/en/resid...ers#supreme-m4
    20x40 IG liner pool, Pentair 1.5 hp pump, 30" Ranger sand filter.
    Taylor K-2006 kit, Dolphin M4 Supreme cleaner.
    May 2014
    Ontario, Canada
    Not sure why you would want a remote. I just trow it in the pool and press on and it works. It stops when its full or after 3 hours I believe. When I come back later I just press on again to restart it for another round if needed.
    Easier to haul and install that a 50 ft hose and cleaner.
    Keep it simple.
    What I like over the pump type is I could never leave the crawler running unattended as the pump will run dry when the filter become clog when the cleaner as pickup some dirts or leaves and plugged.
    Or gets jammed in a corner just after I left. If the robots gets jammed it just start backward to release itself. Great unit.
  1. Robotic pool cleaner
    By MPillion in forum --cleanup--
    Last Post: 01-18-2015, 01:01 AM
  2. looking for a robotic cleaner for AG
    By rajung in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-21-2013, 12:40 AM
  3. Robotic cleaner AND a floor cleaner system?
    By Yellowdog in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-29-2011, 10:31 AM
  4. Robotic cleaner owners - how often?
    By eljefe281 in forum Pool Cleaning: Manual or Automatic
    Last Post: 11-20-2006, 04:33 PM
  5. Electric for robotic cleaner
    By luvapool in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-15-2006, 09:40 AM
