Thread: Aquanaut 200 / 400
    jilted is offline Registered+ Thread Analyst jilted 0
    Jun 2011
    Louisiana
    Default Re: Aquanaut 200 / 400
    the polaris that I inherited with the pool never performed real well even fiddling with the resistance things at the wall port. I always questioned the booster at 1" feeding into the larger pipe. I guess the good news is that the larger diameter pipe goes all the way to the pool!
    I showed a friend who is in the market for a new cleaner as well and he ordered the 400 model today so I'll get to see how it works for him first!
    26,500g inground vinyl liner (new liner installed June 2013)
    Hayward 1.5 HP Super Pump - Hayward sand filter (sand changed in spring 2009)
    Compu Pool CPSC36 SWCG - Polaris 380 cleaner
    Sep 2014
    Tucson, AZ
    I just did a quick search and it looks really cool. I also see Penrair has a similar product. I have an old Kreepy Krauly Sandshark by Pentair which works ok but I get a lot of mesquite debris in my pool. So I may consider one of these fancier models some say if they have good performance.
    As for the 1" PVC line feeding a 2" return, yeah, that was rookie move on whoever installed it. Booster pumps are meant to increase flow rate so if you put lots of resistance in the way, it chokes off the flow. Anyway, neither here nor there as you intend to modify your plumbing.
    Good luck.
