Results 1 to 10 of 11
Thread: ps233 PH results do not match Hanna digital PH tester!
Threaded View
  1. #5
    Default Re: ps233 PH results do not match Hanna digital PH tester!
    Have you tried checking the pH of the pH 7 standard with the drop kit? Might prove enlightening. Phenol red indicator is pretty accurate but I have seen standard solotions that have changed pH. Depends on how they were stored and how fresh they are. I still lean toward the phenol red indicator.
