Results 1 to 3 of 3
Thread: Replacing reagents in the K2006 kit
    Jul 2014
    Madison, WI
    Default Replacing reagents in the K2006 kit
    _________________________________________________
    Admin Edit:
    Please use the updated version of this post. PoolDoc
    Sorry in advance if this is in a FAQ somewhere, but I had heard some of the test reagents from my K2006 might not be good the next year. Just curious what these might be? I'm heading to the store tomorrow to pick up some chlorine and will get new reagents if needed.
    Thanks!
    26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
    Virginia
    Default Re: What test reagents to replace from last years K2006 kit?
    Keeping my Taylor reagents inside the house protected from heat and light I've had no issues getting at least 2 seasons out of them.
    22'x40' Grecian Lazy L 20K gal IG vinyl pool; Aqua Rite SWCG T15 cell; Hayward Pro Grid 6020 DE filter; Hayward Superpump 1hp pump; 12 hrs; Taylor K-2006; city; PF:6
    California
    See Recognizing a Compromised Reagent from the Taylor website. I list below the chemicals found in various kits, grouped roughly by shelf life based on their content.
    Indicator Dyes and FAS-DPD
    (most sensitive; replace at least every 2 years if kept in cool dark place; if not cool, replace every year)
    • R-0004/R-0014 Phenol red pH indicator dye
      also contains a mix of proprietary chlorine neutralizers (not thiosulfate)
    • R-0600 Orthotolidine (OTO), chlorine indicator dye
    • R-0870 N, N-diethyl-p-phenylenediamine (DPD)
      powdered indicator dye plus phosphate buffer, EDTA and organic acid
    • R-0871 Ferrous ammonium sulfate (FAS), titrant reagent
    • R-0008 Bromocresol green and Methyl red, Total Alkalinity (TA) indicator combination dye
    • R-0011L 1 - (Calcon indicator), Calcium Hardness (CH) indicator dye
    Indeterminate shelf-life play it safe and replace every 2 years
    • R-0003 Potassium iodide
      used for combined chlorine (CC) test or total chlorine (TC) tests - sunlight plus oxygen oxidizes it
    • R-0007 Sodium thiosulfate, chlorine neutralizer
    • R-0012 Ethylenediaminetetraacetic acid (EDTA), Calcium Hardness (CH) titrating reagent -- published shelf-life 18-48 months
    • R-0013 Melamine, Cyanuric Acid (CYA) reagent
    Acids/Bases
    (least sensitive; essentially no degradation)
    • R-0005 Hydrochloric acid, acid demand reagent
    • R-0006 Sodium hydroxide, base demand reagent
    • R-0009 Sulfuric acid, for TA titration
    • R-0010 Sodium hydroxide, Calcium Hardness (CH) buffer
    15.5'x32' rectangle 16K gal IG concrete pool; 12.5% chlorinating liquid by hand; Jandy CL340 cartridge filter; Pentair Intelliflo VF pump; 8hrs; Taylor K-2006 and TFTestkits TF-100; utility water; summer: automatic; winter: automatic; ; PF:7.5
  1. Replacing old reagents in Taylor test kit
    By jilted in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2013, 03:17 PM
  2. reagents
    By Corrinna in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2010, 03:35 AM
  3. PS 233 - I need the reagents
    By Flagday53 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-25-2009, 11:16 PM
  4. New Kit or new reagents
    By H2OLogged in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-14-2006, 12:10 PM
  5. Reagents for old K-2006
    By KirstenHW in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2006, 02:22 PM
