Thread: Adding CYA
    satj is offline ** No working email address ** satj 0
    texas.
    Default Adding CYA
    We have just purchased CYA for our pool, finally got it where it should be chemically. The question is, should it be added into the pool directly? The place we bought it from said to put it into a sock and let it slowly dissolve.
    Thanks for any help!
    Rehoboth, MA
    Default Re: Adding CYA
    It's your choice - you can either add it into the skimmer or put it in a sock as they suggest. (If you have a sand filter and pour it into the skimmer, don't backwash for at least 5 days). Since it dissolves slowly, it's probably not the best thing to put it directly into the pool. Wait at least 5 days after you put it in to test for CYA.
    Peter
    If you add the CYA to a sock and drop it into your pool, is it safe for kids to go swimming while it's still dissolving?
    Thanks!
    Sandy
    IL.
    Yes, it is.
    duraleigh Guest
    Quote Originally Posted by SandyRipp
    Thanks!
    Sandy
    Safe? Sure....unless they rip it open.
    What are the chances of that?
    Saint Cloud, FL
    This is the way I have been doing it:
    http://www.poolforum.com/pf2/showthread.php?t=1139
    Pat
  1. Adding CYA
    By utahpool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-28-2010, 02:26 PM
  2. low pressure when adding DE.
    By Amir in forum Pool Equipment & Operations
    Last Post: 05-24-2009, 06:10 PM
  3. Adding BBB
    By Water_man in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-22-2008, 09:00 PM
  4. adding cya
    By tara15 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-27-2007, 09:05 PM
  5. adding cya to pools
    By cleland418 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2006, 03:16 PM
