Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 46
Thread: Metal in the water (Fiberglass 35K pool)
    Default Metal in the water (Fiberglass 35K pool)
    Hello,
    I think that I finally figured out that I have a metal stain in the pool.
    I took one little Vitamin C and droped it on the stain, in about 20 seconds I could see a white spot around it. (See Pic before/After)
    Now if someone could tell me how much of Vitamin C powder do I need to treat a 35000 Gallons fiberglass pool.
    My pool was green a week ago because I went on vacation and nobody took care of it.
    After I returned I tried to shock it.
    For the last 3 days water was at around 12-13 PPM every night, but during the day it would drop to 5PPM so I would add more chlorine at around 6 PM.
    My problem is that I don't have anyone to test it 3 times a day.
    My current numbers are:
    PS233 kit
    FC 9PPM
    (was 15PPM before I went to sleep, 12PPM when I woke up, I added 3 QT of bleach and now it is at 9PPM) Temp is 77*F Pool was open for the whole day with the sun.
    So:
    FC 9PPM
    CC .5 (maybe less)
    PH 7.2
    ALK 80-90
    CAL 120-130
    CYA 20-25?
    Please help.
    Thank you,
    B.
    mbar's Avatar
    Ashland, PA
    Default Re: Metal in the water (Fiberglass 35K pool)
    see the post I posted in "brown stains spreading" It answers the question on what to do for stain treatment - feel free to ask any more questions you may have.
    Northeast PA
    When you talk about sequestering agent, which one do you talk about?
    Is there a specific one for a fiberglass pool? Can you guys provide a link if possible as where I could buy it?
    mbar's Avatar
    Ashland, PA
    I used Sequasol this year, the site I bought it from is:
    http://www.focuspools.com/products/G...n-SEQUASOL.asp
    I have also used Jack's Magic and Metal Free, you can google them and find them online. I would use enough according to the directions for the volume of the pool, and a little extra too.
    Northeast PA
    Thank you very much!
    I ordered 4 bottles of SEQUASOL for 35000 Gallons pool, as you said it's better more than not enough.
    I also bought 5 lbs of Vitamin C yesterday from one of the websites that you provided a link for.
    Can't wait for all of it to come so that I could see a true color of my pool again. Tired of seeing this yellowish/brown tint to it.
    Thank you again!
    B.
    mbar's Avatar
    Ashland, PA
    Good luck, and feel free to ask any questions you may have - you're going to love it, it is like magic!
    Northeast PA
    Can someone please tell me how much of Ascorbic Acid do I need to put in a 35K fiberglass pool?
    The metal stain is all over the walls and floor.
    I tried 5 foam cups around the pool but it seems not enough. Acid desolves very quickly and I started to see white streaks on the wall but overall the pool is still not white.
    I have a DE filter EC-75 and it doesn't have a circulate option. It is always filtering. Is it ok? Or should I turn it off while I am doing it?
    Thanks,
    B.
    mbar's Avatar
    Ashland, PA
    You will need about 3 or 4 lbs. I use anywhere from 1 to 2 in 16,500 gal. It is ok to turn the pump off and walk around the pool, dropping the ascorbic acid down the sides of the pool. Once it is all dissolved, you can put your pump back on and let it filter. Let it filter 24/7. I would start with 3 lbs, and then if all the stain isn't gone in 1 hour walk around and put the other pound in where you still see the stain. Keep me informed, and feel free to ask any questions you have.
    Northeast PA
    I used about 3.5-4 lbs of Ascorbic Powder, can't say exactly, but I still have about 20% left in the bag.
    2 hours later I droped 4 bottles of Sequasol.
    I can still see stains in some places they are very lite, but mostly it's looking good.
    Do you think it is ok to add more of Ascorbic Acid even though I already added a Sequasol?
    When I am adding Ascorbic Acid it looks like it disolves before even reaching the bottom of the pool.
    My Chlorine level is 0
    Thanks,
    B
    mbar's Avatar
    Ashland, PA
    It does dissolve before reaching the bottom. It is fine to add sequasol right after the ascorbic acid - and not a problem to add the ascorbic acid after. I would wait a while befor adding more, I think after the water filters for a while it will take the rest of the stain off. You can add more ascorbic acid, but it will just take longer for the pool to hold chlorine. The pool won't hold chlorine till the chlorine eats up all the ascorbic acid that is in the water, that's why I try to use as little as possible. You can even wait till tomorrow to add more if you still have stain. Congrats! you're almost finished!
    Northeast PA
  1. Metal Stain Treatment + (Combined) Chorine = Pea Soup Green Pool Water
    By ChuckDavis in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-13-2013, 06:08 PM
  2. New Pool Owner 15X42 Intex Metal Frame - very rusty brown well water
    By Heidi B in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-03-2012, 01:41 PM
  3. Looking for concise help with clearing up brown-metal rich pool water
    By bsullivan in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-02-2012, 11:52 AM
  4. First pool, water is clear but fiberglass is stained and lots of scale
    By MountainStone in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-15-2012, 11:14 PM
  5. Just painted my old 45 year old fiberglass pool and refilled with well water.
    By gwingard in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-13-2011, 01:00 PM
