Results 1 to 10 of 46
Thread: Metal in the water (Fiberglass 35K pool)
    mbar's Avatar
    Ashland, PA
    Default Re: Metal in the water (Fiberglass 35K pool)
    You can start to bring the chlorine up to 5. You can keep adding it to go up by adding enough to go up 1 to 2 ppms at a time. You just want to watch to see if any stains start to appear - if they do then add more sequesterant. Keep your ph no higher than 7.2 till all the cloudiness goes away. I would backwash the filter now.
    Northeast PA
    Hello everybody! Today is a day 6 after I added Ascorbic Powder.
    Backwashed my filter yesterday and added 7lbs of DE.
    Droped 3 bottles of 96 oz. Chlorine yesterday and today my Chlorine is at .5 again. The water is a little clearer and I can see bottom drain better than before.
    Can't keep it up yet (Chlorine). I added 2 more bottles today and left to work. I'll add 2 more at around 5 PM.
    PH keeps going up instead of going down. Today it is higher than 7.2 but lower than 7.5. I don't know what is going on with it. Could it be because my return eyeballs facing up? Arriation? Or because we had rain for 3 days non-stop.
    What do you guys think?
    Thanks,
    B
    mbar's Avatar
    Ashland, PA
    Yes, you probably are aerating the pool - better check your alkalinity - it may be low. If it is add baking soda, and if the ph goes any higher than 7.4 make sure you add acid to bring it back down. If your ph gets high, make sure your chlorine is on the low end of your cya chart. Remember high ph with high chlorine lets metals precipitate out, so keep your eye on the pool, if you start to see stains take your ph back down to 7 and add more sequestering agent. Since you have a DE filter, you can add a trichlor puck to your skimmer basket.
    Northeast PA
    Today the water looked crystal clear, for some reason all of my CYA is gone. Added 6 lbs.
    Stains--- Some stains are still there, droped Vitamin C and it desappears. Maybe I should drop more Ascorbic Acid? Maybe not enough Sequestaring Agent? 4 bottles? 35K pool I thought should be enough.
    What do you think? I don't want to get cloudy water again.
    Thanks,
    B
    mbar's Avatar
    Ashland, PA
    Were all of the stains gone first, and coming back now - or were they never lifted off in the first place. If the stains just came back, drop your ph back to 7 and add more sequestering agent. If the stains never came off in the first place, add more ascorbic acid and let the pump circulate for a while. Your water shouldn't get very cloudy again, maybe just a little. You don't need to take you chlorine down again, but watch it because the ascorbic acid will use up the chlorine fast. I am surprised about the cya, did you lose any water?
    Northeast PA
    Since I added Ascorbic acid from the plastic cup around the walls of the pool, stains came off that were close to the walls at the begining, then water became cloudy and after that they came back.
    Now (as it was before) the whole floor of the pool is covered with a layer of stain.
    As you know I bought 5 lbs of Ascorbic Acid and 4 bottles of Sequestering Agent, I used 4lbs and all 4 bottles on day one when I started all that.
    Yesterday I poured in 2 more bottles of Metal Out with the pump off. Direction was to have the pump off for 8 hours (for stain removal process). It didn't do anything to the stains.
    I had about a pound of Ascorbic Acid left in the bag so I droped it in and as soon as Ascorbic Acid touched the floor of the pool stain started to disappear around those spots. So I know that it is deffinately a metal.
    CYA went down for no reason, I already put in 6 lbs of CYA into the pool and now it is back at 20-30. Haven't shocked the pool yet since the time I started all of this.
    Now I don't have Ascorbic Acid anymore, all 5 lbs are gone, stain still there, sequestering agent is gone LOL. And I am out of $130. Expensive treatment that didn't do much. Don't get mad guys it's not your fault. Thanks for helping me. I am out of ideas on how much more of this freaking acid do I have to add.
    B,
    So sorry to hear that. Don't spend another dime yet. How's your PH? Go ahead and post all your numbers. Also, you may want to take a sample to a "reputable" pool store, if you can find one , and get them to test for metals so we know which metal is giving you the problems. Bring a sample of your tap water as well for testing.
    Dave
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    Quote Originally Posted by blk133
    You know, I thought it was weird or maybe my test was off or something but all my CYA dissapeared during my AA treatment too. I have got to get some more in the water. I didn't lose any water or do any water changes or anything, just can't find any CYA in my pool anymore when I test. I was at around 40 before the treatment.
    mbar's Avatar
    Ashland, PA
    blk133, I feel your pain. YOur numbers are perfect. The same thing happened to me too last year. I still don't understand it - my water doesn't test positive for metals either, but I do get staining. I know that if the stain is out on the pool, the water won't test positive for metals , and if the metals are bonded to a sequetering agent, then they won't test positive either. I have read that fiberglass is magnetic, and that you should keep calcium at 300, so the metal doesn't leach out - I just don't know if I beleive it. I know that calcium is a metal, so I would imagaine it would cause staining if there is too much in the water. I had the worst stain the year the pool company put so much calcium in my water it measured 550. So the calcium thing is something I have a hard time with. I haven't had any staining problems this year - I have my calcium level really low because of all the rain we have had. It is only at about 80 and I don't have stains. There is so much conflicting information out there. What I think may have happened to your pool is that there isn't enough sequesterer in the water, and the metals precipitated out again. Waterbear (Evan) has found a product by Proteam called metal magic, that is supposed to bind onto the metals and turn them into crystals which can then be filtered out - which means that they will be gone, and unable to restain! I have ordered some, it hasn't arrived yet. I have a friend that is having trouble with stains this year. I am going to try it on both my pool and hers. I will post the results I have. I am afraid that the water will get cloudy for a while, since the metals will turn to crystals, but it is a small price to pay to get them out once and for all. You will have to do the ascorbic acid again though to get the metals back into solution before using the metal magic. Waterbear said the proteam stain treatment is ascorbic acid, so the regular plain ascorbic acid will work to take the stains off, then you can use the metal magic to crystalize them and filter them out. Here is interesting iinfo I found from the San Juan web site:
    METAL PLATING (DISCOLORATION)
    Top
    Most fill water contains trace to measurable amounts of metals. Because these metals are completely dissolved in the water, they are invisible. Fiberglass acts as a magnet, attracting these metals and plating the gel-coat surface. This plating will not rub or brush off and appears as blotches or shading and may even take on bizarre appearances such as hand or foot prints. Iron deposits appear reddish or light brown, copper will be green or blue green, magnesium or cobalt is black. This plating can be removed almost immediately with the addition of metal removing agents to your pool water. Note: sequestering agents are not effective. Two products are very effective in removing these deposits. Metal Magic by Proteam Products and Jacks Magic by Crystaline Products. Metal Magic attacks all metals and converts them to a metal salt which is removed in the filtering process. Follow label instructions for proper application. Because calcium is a metal, occasionally metal magic will cause the calcium in your pool water to form cloudiness. Continuous filtration may remove this cloudiness. If not, a flocking agent can be used to settle the sediment to the pool floor where it can be vacuumed out. Contact your San Juan Dealer or pool professional for further information on flocking agents.
    Jacks Magic will effectively remove iron deposits from the pools surface but will not remove it from the water. An additional Jacks product must be added to coagulate the metals into a filterable mass. Pools sanitized with chlorine must have chlorine levels reduced or removed for Jacks Magic to be effective.
    So, there you have it - It just keeps getting more and more confusing - but if this really works, it will be great. I think it is worth a try. All of the advice I give on this forum is from my own experience, or from what I have read that seems to fit to me. that is why I want to try out this product, so I can let others know if it works.
    Northeast PA
    Jul 2006
    Marie, may I ask who you purchased your pool from?
    Tisha
