Thread: How to Clean Build-up Off of Vinyl Walls
    Default Re: How to Clean Build-up Off of Vinyl Walls
    Are you sure it isn't mineral buildup from hard water? Maybe just spray it down or use a damp cloth to see if it actually comes off easily. If not, there is a product called "Metal Myte" that is used for mineral deposits and iron in the water - a bit on a damp rag will remove mineral deposits as well as rust stains on vinyl. It is also a very great product for iron/rust in the water itself.
    The stains are pretty stuck to the walls. I tried wiping them with my hand, scratching them, and wiping with a wet cloth. They wouldn't budge, not even flake off.
    It's almost like the vinyl walls have a concrete finish!
    Sounds like mineral buildup to me, if it was shock, it would have eaten the liner by now.
    Use vinyl cleaner on a white scotch brite abrassive pad - use WHITE only since it is the only one that will not harm the liner, teh other colors have abrasives in them.
    Hi All, I wanted to follow up on original post.
    I've had my pool up for about a month, and the crusty white build-up is gradually going away on it's own. My water has been consistantly at
    Alk 80
    pH 7.5
    TC 1.5 to 2
    Thanks for your help!
