Results 1 to 8 of 8
Thread: New AutoPilot help
    IL.
    Default Re: New AutoPilot help
    Correct me if I'm wrong, but if the SWG is working, it is continually super chlorinating the water in the cell, even if the chlorine is eventually lost to the sun when returned to the pool.
    I wouldn't panic.
    Davenj is offline Lifetime Member Thread Analyst Davenj 0
    Jersey Shore
    Its not good for the life of the cell to keep it at 100%. I use a 48 cell set at power level 2 and reduced it 43%, water temp. 84. Keeps my cl at 2ppm with a cya of 60.
    Dec 2005
    South Carolina
    Poolbee,
    Have you tested your water to know how balanced everything is?
    You can refer to your Autopilot manual, or download one off their website to see the recomended ranges for pH, Salinity, Alk, CYA, etc. They pretty much mirror the best practices preached here on the forum (excluding the CYA).
    If you've got salt in the pool, power to the unit, flow through the cell, and no error messages on the unit, you are producing chlorine.
    Search the forum for all kinds of good info on Autopilot operation. I'm sure you'll be very pleased once you learn the ins and outs of the unit, I know I am!
    Nater
    Saint Cloud, FL
    You definitely need CYA in the pool with a SWCG. At about 60-80 ppm for most pools. The reason is the cell produces a high instantaneous chlorine concentration and a fair amount is immediately used in destroying the chloramines in the water at the cell. The CYA prevents the remaining chlorine from being used up until it gets into the pool itself.
    I think that is what Poolsean or Mark mentioned but I may be corrected.
    Pat
