Thread: Troubleshooting Pentair Ultratemp temperature reading
    Apr 2012
    St. Louis metro area
    Default Troubleshooting Pentair Ultratemp temperature reading
    My Ultratemp had been working just fine upon opening of the pool, but I didn't notice it running this last week. We hadn't been in the pool, so no big deal. When I opened the cover on Sunday to swim with my son, the water was nowhere near the 86 degree setting on the heat pump. I toggled to Spa mode and the heat pump fired right up. I toggled back to Pool mode and noticed that the Act temp displayed showed 95 degrees. I'm wondering if I've got a bad thermostat on the heat pump. Any ideas? Thanks.
    11,700 gallon Leisure Elegance 27 fiberglass pool, Pentair Intelliflo pump, IntelliChlor IC20 ECG, UltraTemp heat pump, IntelliBrite 5g LED light, EasyTouch 4, DeckJet II, Automatic Pool Covers AutoGuard Top Track
    Sep 2014
    Tucson, AZ
    Default Re: Troubleshooting Pentair Ultratemp temperature reading
    Dumb question -
    Are you sure the UltraTemp is set to "HEAT Mode" while the control system is in POOL mode?
    I have a MasterTemp gas heater with a Pentair IntelliTouch/EasyTouch control system and I know that the heater settings are separate for each valve mode (POOL vs SPA).
    Other than that, I would check all of your temperature sensors (I have two external temperature sensors, one for water temp and one for air temp) and they control the MasterTemp. The only other temperature control would be internal to the heater and it would be a HIGH TEMP cutoff switch that would kick in if the water temperature got too high.
    Also, check that you are getting good water pressure/flow into the UltraTemp. It could be that, in SPA mode, you have adequate flow but then the flow is too low in POOL mode.
    Hope you find it....hate those little glitches that drive you nuts trying to find them.....as a last resort, you could always call up Pentair Technical Support and they might have some ideas on different points to check.
