Results 1 to 10 of 31
Thread: First time opening pool since joining this forum
    May 2014
    Sussex, WI
    Default Re: First time opening pool since joining this forum
    Water is green and cloudy
    25k gal pool, 18 x 36, 3' to 8' depth. Vinyl lined. Single speed pump
    Jul 2013
    Northern Illinois
    Bummer. More questions:
    1) did you retest? If so, did you register any FC/CC?
    2) can you see the bottom? If so, is there any gunk you can clean out? If not, use your leaf Rake and see if you can dig up any organics in there.
    3) did you add cya yet? If not, don't.
    4) how is your supply of 0871 and powder for testing? You will need a good supply for your next steps.
    May 2014
    Sussex, WI
    I did retest. FC is 4, CC is 2. I can't see the bottom. I did add the CYA. I'll have to start cleaning the debris of the bottom over the next few days. It's going to be a cool week, so I'm not too concerned about having it ready for the weekend.
    Jul 2013
    Northern Illinois
    Okay. Read CarlD's excellent post here: http://www.poolforum.com/pf2/showthr...You-have-ALGAE!!!
    Towards the bottom it talks about algae and the importance of brushing, etc.
    Get the crud out ASAP as it will use up your chlorine as fast as you put it in. Your high CC proves this.
    Bring your FC up to 15 and keep it there, not letting it drop below 12. Keep your pump on continuously.
    If adding 1/2 gallon of 8.25% brought you to FC of 4, your pool volume might very well be less than you think.
    A green, cloudy pool would not be clear by this weekend anyway; it will take a while, sorry.
    Stock up on bleach, Taylor reagent R-0871, and patience.
    Let us know how it goes and if you have any other questions. Wishing you good luck!
    May 2014
    Sussex, WI
    Hi again, I'm working on getting the crud out. It appears to be working. The color has gone from a deep green to a light green. It's still got a lot of brushing and pool cleaner work to go, but i'm seeing progress.
    I'm sure I've got 25,000 gallons, I actually added a full gallon of 12.5% to get my FC to 4.
    2 gallons of 12.5% and a gallon of acid over the past 3 day, my ph is down to 7.4, but my FC/CC is only 3/.4. So I added another 2 gallons tonight of 12.5% to get that chlorine level up. I m considering some clarifier to get the finer granules to clump, but I'll wait to see how the weekend goes.
    Jul 2013
    Northern Illinois
    No clarifier, please. Good job on the crud. Thanks for explaining the FC results. What kind of filter do you have?
    May 2014
    Sussex, WI
    Our filter is a sand filter, not sure what brand though. Why no clarifier? I wasn't planing on buying any, I have about a pint left from when I was trusting the local pool store for advice.
    Just did my chem tests. FC/CC is great. 13.6/.2. PH is 7.2. the only issue was my CYA was under 20. I added enough acid to bring it up to around 30.
