Thread: Need some advise water not clear yet
    Default Need some advise water not clear yet
    36,000 gallon
    salt chlorination
    cartridge filter
    Every spring when I open the pool it is a green mess. I follow the instructions
    here http://www.poolforum.com/pf2/showthr...for-the-Winter
    to close it. Like normal I have no CYA when opening, 0 Chlorine, low PH. I opened the pool got the CYA up to 35, PH up to 7.5, pump running 24/7 and chlorine levels at 15ppm. I have dumped 40 gallons of chlorine in the pool before relying on the salt system to chlorinate. I have been keeping the chlorine level at 15ppm.
    My current numbers are
    FC 13
    CC .5
    PH 7.5
    Alk 70
    Cal 30
    CYA 35
    Pool is still cloudy. I can see the drain in the bottom end now but it has been open for days and normally it never takes more than 7. Any help would be appreciated. Maybe I am being impatient.
    Apr 2014
    richmond,va
    Default Re: Need some advise water not clear yet
    Have you shocked your pool? I would do that first to get rid of the CC. Clean you filter if you haven't recently. I have had the same issue and have had to use a clarifier so far this season. But I have a sand filter and it seems to struggle to get the smallest particles that cause the cloudiness. Keep your pump running 24/7. Good luck.
    18x34 22k gallon IG, Vinyl liner, Hayward sand filter, Hayward Chlorinator, Pentair Challenger 1hp pump, LA Spa.
    Thanks for the reply. I was under the assumption that 15 ppm was a shock level for my cya. How high is considered shock?
    Jul 2013
    Northern Illinois
    Yes, 15 is your shock level. I think patience is the thing...!
