Re: pool lighting
1. Yes
2. I do, it's a matter of opinion - and safety if you swim at night. There's an inherent risk in swimming in dark water at night. You might not notice a drowning swimmer until it is too late.
3. LED is the most energy efficient, and it can produce white light. Incandescent lights produce yellow light and it makes your pool look green when lit. Bright blue with a white LED.
Before you go about replacing the whole light, see if you can replace just the bulb. If you unscrew the screw from the top of the light it should float to the surface. There should be a few feet of extra cable and you can pull it out of the water. Take it apart and see if you can find a replacement bulb. You will probably need to replace the gasket between the glass and metal "back" of the light when you do this. Otherwise there's a good chance it will leak when you re-assemble.
If you do end up replacing the whole thing I'd go LED. You can get 12v or 120v depending on what your current system is on. It's probably easiest just to continue with the voltage you've already got. A n incandescent or halogen pool bulb can be several hundred watts. An LED will probably be well under 100 to put out a reasonable amount of light.
I went with a color changing LED. It's great for night time parties - pool or not. Fun for the kids on occasion as well. In the end, you don't need LED. It's a question of whether or not you think the color and lower power consumption are worth the cost. If you use the light a lot it might not take too long for the energy savings to pay the price difference.
